HardKey Issue ?
HardKey Issue ?
Postby Testman » Thu Oct 03, 2013 1:08 pm
HardKey Issue ?
For my development workstation, everything is fine: hardkey is detected and runs MI in standard mode.
For my deployment workstation, there is an odd issue: the hardkey is detected (ie: upgrading tool says detected and MIu runs wihtout error with the hardkey) however it only runs MI in a mode that has both the signal generator and oscilliscope. No spectrum analyzer, which is why we purchased the software.
Thoughts?
cihequipment
Post at 15-7-2011 03:17
A complete re-installation of MI should solve the problem on the deployment workstation. Most likely, the deloyment workstation was configured to use the ASIO driver during the software's trial period. You need an MI Pro license in order to use the ASIO driver under the licensed mode. The problem will occur if you use a USB hardkey with a license level lower than MI Pro.
Post at 15-7-2011 13:22
Users browsing this forum: No registered users and 18 guests
