When I load the attached PSF MI immediately crashes. Also the Signal Generator window is so wide it extends across three monitors and it cannot be made smaller unless it is closed and re opened. See the attached files
This issue has been resolved in Version 3.6.0.5 which can be downloaded from: http://www.virtins.com/MIsetup.exe. The following screen shot shows two instances of Multi-Instrument running on two different monitors with different screen resolutions.
