Multi-Instrument
Get Multi-Instrument
Buy Multi-Instrument
The software license is perpetual, with no annual fees. Software upgrades are free for life for the same license level!
MI
Multi-Instrument Free Trial
Download
Multi-Instrument
Multi-Instrument
Note: The Full Package includes the Pro version along with all add-on modules.
Find out more:
Brochure
Manual
Spectrum 3D Plots
Multi-Instrument Add-On Modules
The add-on modules need to be purchased separately. They can only run with Multi-Instrument Lite, Standard, or Pro, with the exception that Vibrometer can only run with Multi-Instrument Standard or Pro.
Upgrade
Multi-Instrument License Upgrade
The license information in the softkey, hardkey and VT hardware are all remotely upgradable. For license options, please refer to the paragraph below.
USB Hard Keys
USB Hardkey for Multi-Instrument Series (US$59.95)
The USB hardkey does not require a driver to run. It will be initialized to the corresponding license level purchased. With this option, you can run the software on the registered computer with the softkey, as well as on any computer with the hardkey.
License Options:
1. Softkey activated license (which locks to the registered computer)
2. VT hardware activated license (which locks to the purchased VT hardware)
Optionally, a USB hardkey (which locks to the hardkey) can be purchased per softkey or VT hardware activated license.
Introduction
Multi-Instrument is a powerful multi-function virtual instrument software. It is a professional tool for time, frequency, time-frequency and modulation domain analyses. It supports a variety of hardware ranging from sound cards which are available in almost all computers to proprietary ADC and DAC hardware such as NI DAQmx cards, VT DSOs, VT RTAs and so on. It consists of the following instruments and functions, all of which can run simultaneously and in real time.
Multi-Instrument Animation
Oscilloscope
  • Digital Oscilloscope
  • Transient Recorder
  • Data Recorder
  • Voltmeter
  • Lissajous Plot
  • Digital Filters
  • Persistence Mode
  • Equivalent Time Sampling
  • AM, FM, PM Demodulator
  • Reverberation Analysis
  • Speech Intelligibility
  • Step Response Analysis
  • Echo Sounder
  • Damping Ratio
Signal Generator
  • Function Generator
  • Arbitrary Generator
  • Burst Generator
  • White Noise Generator
  • Pink Noise Generator
  • MultiTone Generator
  • MLS Generator
  • Musical Scale Generator
  • DTMF Generator
  • Frequency Sweep
  • Amplitude Sweep
  • Fade In/Fade Out
  • AM, FM, PM Modulator
  • DDS & Streaming Modes
  • DC Offset supported
Multimeter
  • Voltmeter
  • SPL Meter
  • Frequency Counter
  • RPM Meter Counter
  • Duty Cycle Meter
  • F/V Converter
  • Pulse Width
Derived Data Curves
  • Energy Time Curves
  • Step Response Curve
  • Frequency Time Curves
  • X-Y Plots
  • Shock Response Spectrum
Spectrum Analyzer
  • Amplitude Spectrum Analyzer
  • Power Spectrum Analyzer
  • Real Time Analyzer
  • Octave Analyzer
  • Phase Spectrum Analyzer
  • Correlation Analyzer
  • Freq. Response Measurement
  • Distortion Analyzer
  • Noise Analyzer
  • Harmonics Analyzer
  • Dynamic Signal Analyzer
  • Coherence Measurement
  • Transfer Function Measurement
  • Impulse Response Measurement
  • Wow & Flutter Measurement
  • Sound Quality Measurement
  • Impedance Analyzer
Spectrum 3D Plot
  • Waterfall Plot
  • Spectrogram
  • Cumulative Spectral Decay
Vibrometer
  • Displacement Velocity Acceleration Conversion
Data Logger
  • 8x8 Derived Data Point Logger
  • 254 Derived Data Points
  • 16 User Defined Data Points
Device Test Plan
  • User Defined Plan
  • 8 X-Y Plots
  • 1 Test Report
LCR Meter
  • Inductor Meter
  • Capacitor Meter
  • Resistor Meter
  • Impedance Meter
Derived Data Point (DDP) Viewer
  • Display Derived Data Points
  • HH, H, L, LL Alarming
  • User Defined Data Points
  • DDP Array Viewer
Software Customization & Development
  • Most Flexible Configuration
  • ActiveX Automation Supported
  • vtDAQ & vtDAO Open Interfaces
  • VC++, VB, VC#, Python, LabVIEWE sample codes
System Requirement
Windows XP/VISTA/7/8/10/11, 32 or 64 bit, screen resolution 1024x600 or higher.
ADC/DAC Hardware supported
  • 8/16/24/32 bit Windows compatible sound card (MME/ASIO driver)
  • NI DAQmx compatible cards
  • VT DSO F1/H1/H2/H3 series
  • VT DAQ 1/2 series
  • VT DAO 1 series...
Language supported
  • English
  • French
  • German
  • Italian
  • Spanish
  • Portuguese
  • Russian
  • Simplified Chinese
  • Traditional Chinese
  • Japanese
  • Korean...
Multi-Instrument has been widely used in education and training, scientific research, audio and acoustic engineering, electronic engineering, vibration analysis, medical diagnosis, musical instrument inspection, and so on. Download it now for a 21-day fully functional FREE trial, using your computer sound card as the ADC and DAC devices.
The Multi-Instrument system
A Multi-Instrument system consists of three layers (from front end to back end, as shown in the figure below): sensor layer, data acquisition hardware layer and virtual instrument software layer (i.e. Multi-Instrument).
1. Sensor Layer
The sensor layer is made up of sensors and their pre-amplifiers (if necessary). It converts physical quantities to electronic signals which can then be quantized by the data acquisition layer. It defines the field of application of the Multi-Instrument system. For example, a passive oscilloscope probe or an active differential oscilloscope probe can be used to measure electronic or electrical voltage signals; a current clamp can be used to measure electronic or electrical current signals; a microphone can be used to sense sounds, an acceleration sensor can be used to sense vibration; an ECG sensor can be used to sense the electrical activity of the heart, etc... The sensor layer can also contain actuators such as speakers and vibration shakers.
2. Data Acquisition Hardware Layer
The data acquisition hardware layer contains the data acquisition hardware such as Virtins Technology's PC based USB Oscilloscopes, Spectrum Analyzers and Signal Generators, Virtins Technology's Real Time Analyzers, NI DAQmx cards, sound cards, etc. It scales, conditions and quantizes the electronic or electrical signals passed on by the sensor layer. Together with the sensor layer, it defines the measurement accuracy and precision of the Multi-Instrument system. This layer can also contain DAC hardware which converts the digial signal from the computer to analog signal in order to drive the actuators such as speakers in the sensor layer.
3. Virtual Instrument Software Layer
The virtual instrument software layer is dominated by the Multi-Instrument software. It defines the functions and Graphical User Interfaces (GUI) of the Multi-Instrument system. In general, the Multi-Instrument system is extremely powerful, flexible, customizable, yet cost-effective. Simply through software configuration without any coding, it is possible to achieve custom functions that can only be realized through custom software development using programming tools such as Labview, Matlab, C++, etc. A properly configured Multi-Instrument system will meet your every need in test, measurement, monitoring and control.
Multi-Instrument-System
Function Allocation in Different License Levels
A complete Multi-Instrument software package consists of basic and add-on modules with all features in each of them. The basic modules include Oscilloscope, Spectrum Analyzer, Signal Generator, Multimeter, Derived Data Point Viewer, Derived Data Curve, and General Functions. The add-on modules include Spectrum 3D Plot, Data Logger, LCR Meter, Device Test Plan, Vibrometer, and Dedicated Hardware Support.
There are six license levels to access the basic modules: Sound Card Oscilloscope, Sound Card Spectrum Analyzer, Sound Card Signal Generator, Multi-Instrument Lite, Multi-Instrument Standard, and Multi-Instrument Pro. The add-on modules need to be purchased separately. They can only run with Multi-Instrument Lite, Standard, or Pro, except that Vibrometer can only run with Multi-Instrument Standard or Pro. The following table shows the function allocation among different license levels. Please note that a license of Multi-Instrument Full Package contains Multi-Instrument Pro and all add-on modules.
Basic Modules
✔ - Function available
* - Function available in Multi-Instrument Full Package only
Functions/Levels Sound Card Oscilloscope Sound Card Spectrum Analyzer Sound Card Signal Generator Multi-Instrument Lite Multi-Instrument Standard Multi-Instrument Pro
US$39.95 US$59.95 US$39.95 US$79.95 US$129.95 US$229.95
General Functions
ADC/DAC Hardware Sound Card MME
Sound Card ASIO
Other Hardware
vtDAQ, vtDAO software development License automatically activated with the presence of the corresponding hardware, e.g. a USB hardkey or a VT DSO.
File Operation Load WAV file
Load TXT file
Load WAV file frame by frame (for long WAV file)
Combine WAV file
Extract data and save them into a new WAV file
Save/load panel setting
Data Export Copy Text to Clipboard
Copy BMP to Clipboard
Print Preview
Print
Export as TXT file
Export as BMP file
Trigger Settings Trigger Mode
Trigger Source
Trigger Edge
Trigger Level
Trigger Delay
High Frequency Rejection
Noise Rejection
Sampling Settings Sampling Rate
Sampling Channels
Sampling Bit Resolution
Record Length
Calibration Input
Output
Probe
Sound Pressure Level
F/V Conversion
Latency for Sync. Output/Input
Sensor Sensitivity
Load Factor for Power Calculation
Graph Operation Zoom
Scroll
Cursor Reader
Marker
Chart Type
Line Width
Color
Fast/Slow Display Mode
Refresh Delay
Font Size
Roll Mode
Reference Curve & Limits
Others Gain Adjustment
Input Peak Indicator
Sound Card Selection
Sampling Parameter Auto Setting
Multilingual GUIs
Show/Hide Toolbar
Lock/Unlock Panel Setting
Hot Panel Setting Toolbar
ActiveX Automation Server
Auto Ranging
Auto Scaling
Input Channel Operation
Oscilloscope
Type Individual Waveform ✔ (offline)
Waveform Addition ✔ (offline)
Waveform Subtraction ✔ (offline)
Waveform Multiplication ✔ (offline)
Lissajous Pattern ✔ (offline)
Inter-Frame Processing Linear Average
Exponential Average
Intra-Frame Time Delay Removal
Demodulation (Intra-Frame) AM
FM
PM
Digital Filtering (Intra-Frame Processing) Remove DC
Rectification
FFT Low Pass
FFT High Pass
FFT Band Pass
FFT Band Stop
FFT Frequency Response
FIR Low Pass
FIR High Pass
FIR Band Pass
FIR Band Stop
FIR Frequency Response
IIR Coefficients
Parameter Measurement Reverberation / Speech Intelligibility
Discontinuity
Echo *
Damping Ratio *
Others Max, Min, Mean, RMS, Skewness, Kurtosis ✔ (offline)
Record Mode
Persistence Display Mode
Equivalent Time Sampling Mode
Analog & Digital Signal Mixed Display
SINC Interpolation
Spectrum Analyzer
Type Amplitude Spectrum / Power Spectrum Density / Impedance Spectrum
Phase Spectrum
Auto-Correlation (Linear / Circular)
Cross-Correlation (Linear / Circular) (Original / Generalized)
Coherence/Non-Coherence
Transfer function/Impedance Analyzer
Impulse Response
Intra-Frame Processing Frequency Compensation
Frequency Weighting
Remove DC
Smoothing via Moving Average
Inter-Frame Processing Peak Hold
Linear Averaging
Exponential Average
Cross Correlation (Cross Power Spectrum Vector Average)
Parameter Measurement THD, THD+N, SNR, SINAD, Noise Level, ENOB
IMD/DIM
Bandwidth
Crosstalk
Harmonics & Phase
Energy in User Defined Frequency Bands
Peaks, SFDR, TD+N
Wow & Flutter *
Sound Loudness
Sound Loudness Level
Sound Sharpness
Sound Articulation Index
Noise Rating & Criterion
Total Non-Coherent Distortion + Noise
GedLee Metric
Sound Intensity *
FFT FFT Size 128~32768
FFT Size 65536~4194034
Intra-Frame Average
Window Function
Window Overlap
Other Octave Analysis (1/1, 1/3, 1/6, 1/12, 1/24, 1/48, 1/96)
Linear / Log Scale for X and Y
Peak Marker / Label
Signal Generator
Waveform Sine
Rectangle
Triangle
Saw Tooth
White Noise
Pink Noise
MultiTones
Arbitrary Waveform
MLS
DTMF
Musical Scale
Wave File
Play Waveform in Oscilloscope
Cyclic Play Waveform in Oscilloscope
Sweep Frequency Sweep (Linear/Log)
Amplitude Sweep (Linear/Log)
Forward + Reverse Sweep
Burst (Mask) Normal Phase
Locked Phase
Window-Shaped Burst
On/Off Amplitude Ratio
Fade Fade In
Fade Out
Modulation AM
FM
PM
Others Software Loopback (all channels)
Software Loopback (1 channel)
Sync. with Oscilloscope
Save as WAV file
Save as TXT file
DDS
DC Offset
Multimeter
Type RMS
dBV
dBu
dBSPL
dB(A)
dB(Z)
dB(C)
Frequency Counter
RPM
Counter
Duty Cycle
Frequency/Voltage
Cycle RMS
Cycle Mean
Pulse Width
Jitter Statistics
Settings Counter Trigger Hysteresis
Counter Trigger Level
Frequency Divider
DDP (Derived Data Point) Viewer
Function DDP & UDDP Display
HH, H, L, LL Alarm
Set Display Precision
Define UDDP
Alarm Sound
Alarm Acknowledge
Linear/Exponential Averge
DDP Array Viewer Harmonic Frequencies, RMS, Phases Report
Octave Bands, RMS, Report
Peak Frequencies, RMS, Phases Report
Frequency Bands, RMS Report
Reverberation / Speech Intelligibility (1/1 Octave)
Reverberation / Speech Intelligibility (1/3 Octave)
Derived Data Curve (DDC)
Function Energy Time Curve (Log-Squared)
Energy Time Curve (Envelop)
Energy Time Curve (dBSPL)
Impulse Response Schroeder Integration Curve
Step Response Curve (via Impulse Response Integration)
Frequency Time Curve (Demodulated)
X-Y Plot
Frequency Time Curve (Timed)
RPM Time Curve
Spectrum Analysis on Selection
Add-on Modules
Blank - Function available if purchased
Shaded Blank - Function NOT available in that license level
Spectrum 3D Plot (US$99.95)
Type Waterfall Plot (Inter-frame, STFT)
Waterfall Plot (Intra-frame, STFT)
Waterfall Plot (Intra-frame, CSD)
Spectrogram (Inter-frame, STFT)
Spectrogram (Intra-frame, STFT)
Spectrogram (Intra-frame, CSD)
Settings Spectrogram Color Palette
Waterfall Color Palette
Waterfall Tilt Angle
Waterfall / Spectrogram Height
Number of Spectral Profiles
(10~200)
Others 3D Cursor Reader
Spectrogram Smoothing
Data Logger (US$99.95)
Real Time Logging
Load historical log file
Three logging methods
270 derived data points available for logging
Up to 8 x 8 = 64 variables can be logged simultaneously
LCR Meter (US$99.95)
High Impedance Measurement
Low Impedance Measurement
Up to 8 X-Y Plots (Linear/Log)
Device Test Plan (US$99.95)
27 Instructions
Create / Edit / Lock / Execute / Load / Save a Device Test Plan
Device Test Plan Log
Automatic Multi-Step Generation
User Log In/ Out
Volatile & Non-volatile Variables
Vibrometer (US$99.95)
RMS, Peak/PP, Crest Factor for acceleration, velocity, displacement (in Multimeter)
Waveform conversion among acceleration, velocity and displacement (in Oscilloscope)
SI/English units
Dedicated Hardware Support (US$99.95)
RTX6001 Remote /Local Control
The Dedicated Hardware Support add-on module is intended for seamless integration with some third-party hardware devices.
The following third-party hardware devices are under this category:
1. RTX6001 Audio Analyzer
Note that without this add-on module, RTX6001 will work as a sound card only and is still supported by Multi-Instrument's generic sound card drivers. With this add-on module, the input and output data will be scaled properly by the software without calibration, and RTX6001 is fully controllable from PC.
Module Specifications and Features
Sound Card Based Measurement System
With the Multi-Instrument softare, without any additional ADC and DAC hardware, you can turn your PC into a multi-function test and measurement instrument by using its built-in sound card as the ADC and DAC devices. The sampling rate can be up to 768 kHz and the sampling bit resolution can be up to 32 bits. The software have a wealth of features normally only found in much more expensive instruments. Generally, the sound card supplied with a PC is sufficient to allow measurements in the audio frequency range. Perfect measurement quality can be archived by using a professional grade sound card. Together with the VIRTINS Sound Card Oscilloscope Probe P601, which has three attenuation positions, the setup is able to measure a signal with a magnitude from as low as 1 µV to 24 V.
You can also integrate sensors, transducers, ADC and DAC hardware (e.g. sound cards, NI DAQmx cards, VT DSOs, VT RTAs, etc.), computers and the Multi-Instrument software together to form a professional test and measurement system.
Accessories for Sound Card Based Measurements
Please refer to VIRTINS Sound Card Oscilloscope Probe Kits P601PC and P601PPC.
