Multi-Instrument
Multi-Instrument Download Multi-Instrument Now!(Download 21-day fully functional FREE trial)        Brochure     Manual
Multi-Instrument
Multi-Instrument Add-on Modules
Multi-Instrument License Upgrade
The license information in the softkey, hardkey and VT hardware are all remotely upgradable.
USB Hardkey for Multi-Instrument Series
US$39.95
Free Express Shipping
It does not need a driver to run and thus is hassle free. It will be initialized to the license level purchased. With this option, you can run the software on the registered computer with the softkey, and on any computer with the hardkey.
Full Package = Pro + all add-on modules, FREE upgrade for the same license level for life!
License Options: 1) Softkey activated license (locks to the registered computer)       2)VT hardware activated license (locks to the purchased VT hardware)
Optionally, a USB hardkey (locks to the hardkey) can be purchased per softkey or VT hardware activated license
1. Introduction
Multi-Instrument is a powerful multi-function virtual instrument software. It is a professional tool for time, frequency and time-frequency domain analyses. It supports a variety of hardware ranging from sound cards which are available in almost all computers to proprietary ADC and DAC hardware such as NI DAQmx cards, VT DSOs, VT RTAs and so on.  It consists of the following instruments and functions.
Sound Card Oscilloscope, Spectrum Analyzer, Signal Generator
Oscilloscope
Digital Oscilloscope
Transient Recorder
Data Recorder
Voltmeter
Lissajous Plot
Digital Filters
Persistence Mode
Equivalent Time Sampling
AM, FM, PM Demodulator
Signal Generator
Function Generator
Arbitrary Generator
Burst Generator
White Noise Generator
Pink Noise Generator
MultiTone Generator
MLS Generator
Musical Scale Generator
DTMF Generator
Frequency Sweep
Amplitude Sweep
Fade In/Fade Out
AM, FM, PM Modulator
DDS & Streaming Modes
DC Offset supported
Multimeter
Voltmeter, SPL Meter,
Frequency Counter, RPM Meter,
Counter, Duty Cycle Meter,
F/V Meter, Pulse Width
Spectrum Analyzer
Amplitude Spectrum Analyzer
Power Spectrum Analyzer
Real Time Analyzer
Octave Analyzer
Phase Spectrum Analyzer
Correlation Analyzer
Freq. Response Measurement
Distortion Analyzer
Noise Analyzer
Harmonics Analyzer
Dynamic Signal Analyzer
Coherence Measurement
Transfer Function Measurement
Impulse Response Measurement
Wow & Flutter Measurement
Sound Quality Measurement
Spectrum 3D Plot
Waterfall Plot
Spectrogram
Vibrometer
Displacement, Velocity, Acceleration
Conversion
Data Logger
8×8 Derived Data Point Logger
185 Derived Data Points
16 User Defined Data Points
Device Test Plan
User Defined Plan
8 X-Y Plots
1 Test Report
LCR Meter
Inductor Meter
Capacitor Meter
Resistor Meter
Impedance Meter
DDP Viewer
Display Derived Data Points
HH, H, L, LL Alarming
Software Customization & Development
Most Flexible Configuration
ActiveX Automation Supported
vtDAQ & vtDAO Open Interfaces
VC++, VB, VC#, Labview Samples
System Requirement
Windows XP/VISTA/7/8/10, 32 or 64 bit, screen resolution 1024×600 or higher.
ADC/DAC Hardware supported
8/16/24 bit Windows compatible sound card (MME/ASIO driver)
NI DAQmx compatible cards
VT DSO F1/H1/H2/H3 series
VT DAQ 1/2 series, VT DAO 1 series
Language supported
English, French, German, Italian, Spanish, Portuguese, Russian
Simplified Chinese, Traditional, Chinese, Japanese, Korean ...
2. Function Allocation in Different License Levels
A complete package of Multi-Instrument software consists of Oscilloscope, Spectrum Analyzer, Signal Generator, Multimeter, Spectrum 3D Plot, Data Logger, LCR Meter, Device Test Plan, Vibrometer with full features in each of them.
The following table shows the function allocation in different editions of Multi-Instrument. Spectrum 3D Plot, Data Logger, LCR Meter, Device Test Plan, Vibrometer are add-on modules/functions and should be purchased separately. They are only available in Multi-Instrument Lite, Standard, and Pro editions, except that Vibrometer is only available in Multi-Instrument Standard and Pro.
                                       Basic Modules               Legend: ✔- Function available            ✔*- Function available in Full version only
Functions\Levels
Sound Card Spectrum Analyzer
Sound Card Signal Generator
Multi-Instrument Pro
US$24.95
US$39.95
US$24.95
US$49.95
US$99.95
US$199.95
General Functions
ADC/DAC Hardware Sound Card MME
Sound Card ASIO
Other Hardware
vtDAQ, vtDAO software development License automatically activated with the presence of the corresponding hardware, e.g. a USB hardkey or a VT DSO.
File Operation Load WAV file
Load TXT file
Load WAV file frame by frame (for long WAV file)
Combine WAV file
Extract data and save them into a new WAV file
Save/load panel setting
Data Export Copy Text to Clipboard
Copy BMP to Clipboard
Print Preview
Print
Export as TXT file
Export as BMP file
Trigger Settings Trigger Mode
Trigger Source
Trigger Edge
Trigger Level
Trigger Delay
High Frequency Rejection
Noise Rejection
Sampling Settings Sampling Rate
Sampling Channels
Sampling Bit Resolution
Record Length
Calibration Input
Output
Probe
Sound Pressure Level
F/V Conversion
Latency for Sync. Output/Input
Sensor Sensitivity
Load Factor for Power Calculation
Graph Operation Zoom
Scroll
Cursor Reader
Marker
Chart Type
Line Width
Color
Fast/Slow Display Mode
Refresh Delay
Font Size
Roll Mode
Reference Curve & Limits
Others Gain Adjustment
Input Peak Indicator
Sound Card Selection
Sampling Parameter Auto Setting
Multilingual GUIs
Show/Hide Toolbar
Lock/Unlock Panel Setting
Hot Panel Setting Toolbar
ActiveX Automation Server
Oscilloscope
Type Individual Waveform (offline)
Waveform Addition (offline)
Waveform Subtraction  (offline)
Waveform Multiplication (offline)
Lissajous Pattern (offline)
Inter-Frame Processing Linear Average
Exponential Average
Demodulation
(Intra-Frame)
AM
FM
PM
Digital Filtering
(Intra-Frame Processing)
Remove DC
Rectification
FFT Low Pass
FFT High Pass
FFT Band Pass
FFT Band Stop
FFT Frequency Response
FIR Low Pass
FIR High Pass
FIR Band Pass
FIR Band Stop
FIR Frequency Response
IIR Coefficients
Others Max, Min, Mean, RMS (offline)
Record Mode
Persistence Display Mode
Equivalent Time Sampling Mode
Analog & Digital Signal Mixed Display
SINC Interpolation
Spectrum Analyzer
Type Amplitude Spectrum
Phase Spectrum
Auto-Correlation
Cross-Correlation
Coherence
Transfer function
Impulse Response
Intra-Frame Processing Frequency Compensation
Frequency Weighting
Remove DC
Smoothing via Moving Average
Inter-Frame Processing Peak Hold
Linear Averaging
Exponential Average
Parameter Measurement THD, THD+N, SNR, SINAD, Noise Level, ENOB
IMD
Bandwidth
Crosstalk
Harmonics & Phase
Energy in User Defined Frequency Bands
Peaks, SFDR
Wow & Flutter           ✔*
Sound Loudness
Sound Loudness Level
FFT FFT Size 128~32768
FFT Size 65536~4194034
Intra-Frame Average
Window Function
Window Overlap
Other Peak Frequency Detection
Cross Correlation Peak Detection
Octave Analysis (1/1, 1/3, 1/6, 1/12, 1/24, 1/48, 1/96)
Linear/Log/Power Spectral Density Scale for X and Y
Signal Generator
Waveform Sine
Rectangle
Triangle
Saw Tooth
White Noise
Pink Noise
MultiTones
Arbitrary Waveform
MLS
DTMF
Musical Scale
Wave File
Play Waveform in Oscilloscope
Cyclic Play Waveform in Oscilloscope
Sweep Frequency Sweep  (Linear/Log)
Amplitude Sweep  (Linear/Log)
Burst (Mask) Normal
Phase Locked
 Fade Fade In
Fade Out
 Modulation AM
FM
PM
Others Software Loopback  (all channels)
Software Loopback  (1 channels)
Sync. with Oscilloscope
Save as WAV file
Save as TXT file
DDS
DC Offset
Multimeter
Type RMS
dBV
dBu
dBSPL
dBSPL(A)
dBSPL(B)
dBSPL(C)
Frequency Counter
RPM
Counter
Duty Cycle
Frequency/Voltage
Cycle RMS
Cycle Mean
Pulse Width
Settings Counter Trigger Hysteresis
Counter Trigger Level
Frequency Divider
DDP Viewer
Function DDP & UDDP Display
HH, H, L, LL Alarm
Set Display Precision
Define UDDP
Alarm Sound
Alarm Acknowledge
                                        Add-on Modules                               Legend:   Blank - Function available if purchased        Shaded Blank - Function NOT available
Functions\Levels Sound Card Oscilloscope Sound Card Spectrum Analyzer Sound Card Signal Generator Multi-Instrument Lite Multi-Instrument Standard Multi-Instrument Pro
Spectrum 3D Plot   (US$99.95)
Type Waterfall Plot
Spectrogram
Settings Spectrogram Color Palette
Waterfall Color Palette
Waterfall Tilt Angle
Waterfall / Spectrogram Height
Linear / Log Scale for X and Y
Number of Spectral Profiles
Others 3D Cursor Reader
Data Logger  (US$99.95)
Real Time Logging
Load historical log file
Three logging methods
201 derived data points available for logging
Up to 8 × 8 = 64 variables can be logged simultaneously
LCR Meter  (US$99.95)
High Impedance Measurement
Low Impedance Measurement
Up to 8 X-Y Plots (Linear/Log)
Device Test Plan  (US$99.95)
23 Instructions
Create / Edit / Lock / Execute / Load / Save a Device Test Plan
Device Test Plan Log
Vibrometer (US$99.95)
RMS, Peak/PP, Crest Factor for acceleration, velocity, displacement   (in Multimeter)
Waveform conversion among acceleration, velocity and displacement (in Oscilloscope)
SI/English units
3. Module Specifications and Features
Oscilloscope
Spectrum Analyzer
Signal Generator
Multimeter
Multimeter
Spectrum 3D Plot
Spectrum 3D Plot
Data Logger
Data Logger
LCR Meter
LCR Meter
Device Test Plan
Device Test Plan
Vibrometer
Vibrometer
DDP Viewer
DDP Viewer
4. Sound Card Based Measurement System
With the Multi-Instrument softare, without any additional ADC and DAC hardware, you can turn your PC into a multi-function test and measurement instrument by using its built-in sound card as the ADC and DAC devices. The sampling rate can be up to768 kHz and the sampling bit resolution can be up to 24 bits. The software have a wealth of features normally only found in much more expensive instruments. Generally, the sound card supplied with a PC is sufficient to allow measurements in the audio frequency range. Perfect measurement quality can be archived by using a professional grade sound card. Together with the VIRTINS Sound Card Oscilloscope Probe P601, which has three attenuation positions, the setup is able to measure a signal with a magnitude from as low as 1 µV to 24 V.
You can also integrate sensors, transducers, ADC and DAC hardware (e.g. sound cards, NI DAQmx cards, VT DSOs, VT RTAs, etc.), computers and the Multi-Instrument software together to form a professional test and measurement system.
5. Accessories for Sound Card Based Measurements
Please refer to VIRTINS Sound Card Oscilloscope Probe Kits P601PC and P601PPC
