VT DSO-2815H
VT DSO-2815H
Postby Testman » Thu Oct 03, 2013 10:33 am
VT DSO-2815H
Hi, Anybody knows if the BNC labelled EXT of VT DSO-2815H is used to output the signal from the signal generator. If not, how do I get the multi instrument signal generator output into my circuit? Thanks, Gabriel
Post at 28-7-2009 21:16
The BNC labelled "EXT" is for external trigger (-4~4V). As indicated in the specification, the signal generator function is available via the computer sound card 's "Line Out" or "Speaker Out".
Post at 30-7-2009 23:45
Thank you for the info,
Gabriel
Post at 31-7-2009 22:54
The 2810H and 2815 have a 1KHz square wave "probe calibration" terminal, I have used it to do some test..
weirdmonkey
Post at 13-8-2011 23:45
Re: VT DSO-2815H
Postby faarisuman » Wed Dec 24, 2014 6:10 pm
At the end I´m trying to modify the parameters of your DTP archives to use 24bits and change the windowing and signal levels, but with no success until now. Could you elaborate a bit more your explanations above for me?
Get fast success in scjp - exam and testking exam questions by using cisco - exam - my braindumps.We also offer nova and www.kumc.edu for your prep of Florida National University.
faarisuman
Re: VT DSO-2815H
Postby VirtinsTech » Mon Jan 05, 2015 9:17 pm
what exactly is your question?
Return to General
