Generate identical white/pink noise for all the channels
Postby Paul » Wed Jun 10, 2020 11:38 am
Dear VIrtins,
Could you please add something like "oA = oB" option in the signal generator?
It would allow users to generate identical white/pink noise for all the channels simultaneously.
I need this function to measure the gain and phase balance vs. frequency between the two channels of DACs.
Thanks a lot!
Cheers,
Paul
Paul
Re: Generate identical white/pink noise for all the channels
Postby VirtinsTech » Fri Jun 12, 2020 4:48 pm
Thanks for the suggestions.
An option will be added in the "..." button on the signal generator panel to allow the user to select whether to make the white and pink noises in both channels identical. It will be included in the coming minor version upgrade.
Meanwhile, with the current version, you can still generate identical periodic white or pink noise via the MultiTone function.
Postby Paul » Fri Jun 12, 2020 9:32 pm
Thank you very much!
I am looking forward to the coming minor version.
Paul
Postby VirtinsTech » Mon Jun 29, 2020 10:42 am
This function has been included in MI 3.9.1 which can be downloaded from www.virtins.com/MIsetup.exe
Return to Wish Lists
Users browsing this forum: No registered users and 6 guests
