Slow UI response for large FFT size
Postby suktan » Fri Aug 14, 2020 12:08 pm
Hello Virtins team,
I downloaded the trial version and evaluating the software. One thing I notice is that the UI response will be very slow for large FFT (> 256k). Is it expected?
Thank you!
suktan
Re: Slow UI response for large FFT size
Postby VirtinsTech » Sun Aug 16, 2020 5:22 am
In our test on a DELL XPS 8900 desktop computer (Intel Core i7-6700 CPU@3.4GHz, 8GB RAM, 64-bit Windows 10), the screen refresh rate is 0.9 second/frame when [FFT Size] = 262144. The trigger mode is set to AUTO so as to eliminate any delay caused by not-satisfying the specified trigger condition. The sampling duration (Oscilloscope Frame Width) is set to 10 ms to make sure the delay is not caused by sampling duration.
Postby suktan » Sat Aug 22, 2020 8:01 am
Thank you.
suktan
Users browsing this forum: Bing [Bot] and 9 guests
