Device Test Plan
lemon
Device Test Plan
Post by lemon »
It will be nice if the next version has the following changes.
- the ability to change the text of X-Y axis
- the ability for a subtitle under the title.
- the ability to change the colors of text for X-Y and title.
- the ability to change the background color of plot.
Re: Device Test Plan
1. The text of X-Y axis can be changed through the alias of DDP to be captured
2. Noted and will be considered in the future.
3. They can be changed via [Setting]>[Display] but not individually.
4. They can be changed via [Setting]>[Display] but not individually.
lemon
Post by lemon »
Thanks for the answer.
1) Yes, it is know, but it needs you adapt all the axis, X-Y Plots, e.t.c every time you want to change something... it is not optimum that!
Have in mind that the Alias text, doesn't accept all the characters, except comma (,), the phrase "THD+N(%)_Ch.A" doesn't accepted-> it converts to "THD+N(%)", the same and with the "THD (%) - Ch.A", it converts to "THD(%)"
I think that you must to redesign the DTP and of course it needs to add the ability to resize the window when you edit it.
