Access to ASIO COntrol panel from DAC or ADC Faceplate
Postby RJA4000 » Sat Nov 05, 2022 4:59 pm
It's always difficult to set up ASIO4ALL configuration without a direct access to the ASIO config panel.
In general, I think that would be a great addition to add an access to the selected DAC/ADC ASIO config panel from Multi-Instrument's DAC or ADC device settings faceplate.
Do you think this is doable ?
Re: Access to ASIO COntrol panel from DAC or ADC Faceplate
Postby VirtinsTech » Mon Nov 07, 2022 2:36 am
Thanks for the suggestion! It will be added in the coming new version.
Postby VirtinsTech » Fri Nov 11, 2022 7:07 am
It has been included in the new release V3.9.7.0 which is now available for download. Thanks!
Postby RJA4000 » Sun Nov 13, 2022 7:27 pm
It works in Build 3.9.7 !
Postby Kruger » Sat Dec 17, 2022 3:20 pm
Thank you! I really nice addition.
Kruger
Postby Kruger » Mon Dec 19, 2022 1:24 am
Reverted back to 3.9.4
ASIO calibration is grayed out and cannot be changed.
Kruger
Postby VirtinsTech » Wed Dec 21, 2022 5:25 pm
which ASIO driver was used when [Setting]>[Calibration]>"Others/ASIO" is grayed out? Is it miniDSP ASIO driver?
If "Others/ASIO" is grayed out when a particular ASIO driver is selected, it usually means that under that ASIO driver, the input gain is somehow still adjustable through "mixer" and the corresponding mixer gain percentage options will be enabled. Calibration should be done with respect to those options.
Postby Kruger » Fri Dec 23, 2022 4:00 am
Hi VirtinsTech,
Yes. It is exactly the miniDSP ASIO driver.
I will try to calibrate according to your advice.
Kruger
Users browsing this forum: No registered users and 10 guests
