Hello,
I want to obtain damping ratio from the transform function. What should I do with the DDP/UDDP?
Thank you.
Obtaining damping ratio from transfer function
Re: Obtaining damping ratio from transfer function
The free vibration decay curve method requires MI full package. To enable damping ratio measurement using this method, right click anywhere within the oscilloscope window and select [Oscilloscope Processing]>"Damping Ratio", the corresponding DDPs are DampingRatio_A and DampingRatio_B.
In the half-power method, the damping ratio can be derived using ([BandWidthHighLimit_A(Hz)]-[BandWidthLowLimit_A(Hz)])/2/[f1Freq_A(Hz)] for Channel A. This formula can be used to define a UDDP.
