Measuring THD
Measuring THD
Postby vincer » Sun Dec 11, 2016 12:56 am
I have externally looped the output of the 2810 to the input. The THD measures between .2 and .3 out to the third harmonic at 1 KHz using a Hamming Window. If the native THD of the instrument is over .1 % , How can I measure the THD of low THD amplifiers?
vincer
Re: Measuring THD
Postby VirtinsTech » Mon Dec 12, 2016 9:54 am
Thank you for your questions. Kaiser 6 window function is recommended for THD measurement. The loopback THD will be a little better if Kaiser 6 window is used instead of Hamming window.
More importantly, VT DSO-2810 is not designed to measure low THD as indicated by its own THD figures in the specifications.
Users browsing this forum: Bing [Bot] and 1 guest
