2 Small bugs (3.9.8.1)
Post by RJA4000 »
2 small bugs:
1/ When I change frequency in generator, it happens often that the application crashes (closes without notice)
2/ Changing the number of points is quite long:
You have to type one figure then click again on the field, then go to the end then type the second figure
and so on.
Re: 2 Small bugs (3.9.8.1)
Post by RJA4000 »
A third one:
When I have complex formula in UDDP (including LOG10 function), MI may crash if there is no signal at the input.
Thanks for the bug reports.
1) unable to reproduce
2) solved in the coming V3.9.9.0
3) unable to reproduce
Post by RJA4000 »
Thanks for 2) already ;-)
I'll try and provide more detils about the 2 other points.
I'll try to find a way to allow you to reproduce.
