First of all, thank you for this outstanding software. I purchased the full package a few days ago and I’m absolutely thrilled with the range of features it offers.
I’m developing a Python script to analyze unweighted wow and flutter, using the methodology described in the “Wow and Flutter Measurement using Multi-Instrument” guide and the MI user manual as a reference. I'm trying to validate the script’s output by comparing it against measurements obtained from Multi-Instrument, but I’m getting inconsistent results.
The script is fairly straightforward and self-explanatory. These are the main steps I'm following:
- 1. Apply a full-length Kaiser 8 window to the audio signal
- 2. Perform a bandpass prefilter (312.9 Hz – 5945 Hz)
- 3. Extract the instantaneous frequency via Hilbert demodulation
- 4. Normalize and remove the DC component
- 5. Apply a 1565 Hz anti-alias low-pass filter
- 6. Compute the absolute value of the deviation (abs)
- 7. Calculate two-sigma (2 × standard deviation) and 95th percentile
However, when using a real signal recorded from my turntable, MI reports 0.45%, while the script gives 0.54% using the 2-sigma method.
Why do I get such different readings? Am I missing an additional processing step?
Any guidance pointing me in the right direction would be greatly appreciated.
Best regards,
Alvaro Oliver
Code: Select all
import numpy as np
from scipy.io import wavfile
from scipy.signal import butter, filtfilt, hilbert, get_window
import matplotlib.pyplot as plt
# -------------------- CONFIG --------------------
#FILE_NAME = "Record1.wav"
FILE_NAME = "04 3150HzModulatedBy4HzAt0.997Percent31.5Hz.wav"
BPF_HI = 5945.0 # bandpass high-pass frequency
BPF_LO = 312.9 # bandpass low-cut frequency
LPF_CUTOFF = 1565.0 # FM demodulation antialias filter (1565.0)
TRIM_MS = 20 # trim 20 ms each side
BETA = 8.0 # Kaiser window parameter
# -------------------- FUNCTIONS --------------------
def bandpass_filter(signal, fs, lowcut=BPF_LO, highcut=BPF_HI, order=4):
nyq = 0.5 * fs
b, a = butter(order, [lowcut / nyq, highcut / nyq], btype='band')
return filtfilt(b, a, signal)
def lowpass_filter(signal, fs, cutoff, order=4):
nyq = 0.5 * fs
b, a = butter(order, cutoff / nyq, btype='low')
# -------------------- MAIN --------------------
# Load WAV audio
fs, data = wavfile.read(FILE_NAME)
TRIM = int(fs * TRIM_MS / 1000)
audio = data.astype(np.float32)
if audio.ndim > 1:
audio = audio[:, 0] # just left chanel
# Fit window to the full length of the audio
audio_len = len(audio)
window = get_window(('kaiser', BETA), audio_len)
block = audio * window
# Instantaneous Frequency
prefiltered = bandpass_filter(block, fs)
analytic = hilbert(prefiltered)
phase = np.unwrap(np.angle(analytic))
inst_freq = np.diff(phase) * fs / (2 * np.pi)
inst_freq = inst_freq[TRIM:-TRIM]
# Normalization
mean_freq = np.mean(inst_freq)
normalized = (inst_freq - mean_freq) / mean_freq # normalization and DC removal
dealiased = lowpass_filter(normalized, fs, LPF_CUTOFF) # antialias postfilter
# Unweighted Wow and Flutter
magnitude = np.abs(dealiased) # deviation magnitude
sigma_2 = 2 * np.std(magnitude) # unweighted peak WnF (2σ)
percentil_95 = np.percentile(magnitude, 95) # percentile 95 peak
t = np.arange(len(dealiased)) / fs # time axis
# -------------------- PLOT RESULTS --------------------
fig = plt.figure(figsize=(14, 10))
fig.suptitle(FILE_NAME, fontsize=12)
# Subplot Layout
ax1 = plt.subplot2grid((3, 2), (0, 0), colspan=2)
ax2 = plt.subplot2grid((3, 2), (1, 0), colspan=2)
ax3 = plt.subplot2grid((3, 2), (2, 0))
ax4 = plt.subplot2grid((3, 2), (2, 1))
# Plot 1: Instantaneous Frequency
ti = np.arange(len(inst_freq)) / fs
ax1.plot(ti, inst_freq, linewidth=0.3)
ax1.axhline(y=mean_freq, color='red', linestyle='--', label=f"Mean: {mean_freq:.2f} Hz", linewidth=1)
ax1.set_xlabel("Time (s)")
ax1.set_title("Instantaneous Frecuency (Hz)")
ax1.legend()
ax1.grid()
# Plot 2: Magnitude
ax2.plot(t, magnitude, linewidth=0.3)
ax2.axhline(y=sigma_2, color='red', linestyle='--', label=f"Unw. WnF (2σ): {sigma_2 * 100:.4f}% peak", linewidth=1)
ax2.axhline(y=percentil_95, color='blue', linestyle='--', label=f"Unw. WnF (P95): {percentil_95 * 100:.4f}% peak", linewidth=1)
ax2.set_title("Normalized Absolute Deviation Magnitude")
ax2.set_xlabel("Time (s)")
ax2.legend()
ax2.grid()
# Plot 3: Spectrum
spectrum = np.abs(np.fft.rfft(dealiased))
freqs = np.fft.rfftfreq(len(dealiased), d=1/fs)
ax3.semilogx(freqs, spectrum / np.max(spectrum), color='purple', alpha=0.7) # eje x logarítmico
ax3.set_title("Spectrum")
ax3.set_xlabel("Frequency (Hz)")
ax3.grid()
ax3.grid(which="minor", color="0.9")
ax3.set_xlim([freqs[1], 1000])
# Plot 4: Histogram
ax4.hist(dealiased, bins=1024, density=True, color='gray', alpha=0.6)
ax4.set_title("Histogram")
ax4.set_xlim(-0.05,0.05)
ax4.grid()
plt.tight_layout(rect=[0, 0, 1, 0.96]) # leave space for filename
plt.show()
