MI Crashes
vincer
MI Crashes
Post by vincer »
When I load the attached PSF MI immediately crashes. Also the Signal Generator window is so wide it extends across three monitors and it cannot be made smaller unless it is closed and re opened. See the attached files
Re: MI Crashes
Could you re-attach the screenshot?
vincer
Re: MI Crashes
Post by vincer »
Here is the screen capture. Open in Paint and expand to right to see entire image.
Re: MI Crashes
sorry, still cannot see the attachment.
vincer
Re: MI Crashes
Post by vincer »
I have uploaded it to dropbox.com and sent you a link via email to: support@virtins.com
vincer
Re: MI Crashes
Post by vincer »
Hey Virtins, where are we with this issue?
Re: MI Crashes
Thanks for this bug report (see the screenshot you sent through email below).
We are working on this and will update the software together with other minor updates in about two weeks.
Re: MI Crashes
This issue has been resolved in Version 3.6.0.5 which can be downloaded from: http://www.virtins.com/MIsetup.exe. The following screen shot shows two instances of Multi-Instrument running on two different monitors with different screen resolutions.
