		1. Derive a dedicated data curve from a frame of sampled data and display it in a standalone graph window.  Maximum 8 DDC windows can be opened.
  2. The DDC window is similar to the X-Y Plot in Device Test Plan except that its context menu contains a [DDC
		Processing] menu item which is used to select a predefined DDC and
		configure its relevant parameters. The supported DDCs are:
      (1)
		Energy Time Curve (Log-Squared)     (2) Energy Time
		Curve (Envelope)
		(3) Energy Time Curve (dBSPL)     (4) Impulse Response
		Schroeder Integration Curve     (5) Step Response
		Curve (via Impulse Response Integration)     (6)
		Frequency Time Curve (Demodulated)     (7) X-Y Plot
		(8) Shock Response Spectrum     (9) Frequency Time
		Curve (Timed)     (10) RPM Time Curve
  3. Supports
		Multilingual User Interface under Windows 2000, XP, Vista, 7, 8,
		8.1, 10, 11 and
		above. Currently supported languages are English, French, German,
		Italian, Portuguese, Spanish, Russian, Simplified Chinese, Traditional
		Chinese, Japanese and Korean.
		Examples:
				Energy Time Curve (Log-Squared) of an Impulse Response
				Energy Time Curve (Envelope) of an Impulse Response
				Energy Time Curve (dBSPL) of an Impulse Response
				Impulse Response Schroeder Integration Curve
				Step Response Curve Integrated from an Impulse Response
				Frequency Time Curve (demodulated) of a Linear Frequency Sweep
				of a Sine Wave
				X-Y Plot:
				Sound Level vs Rotational Speed (Run Up Test)
				   X-Y
				Plot: Frequency Response Measured by Tracking a Linear Frequency
				Sweep
				Shock Response Spectrum of a Half Sine Pulse
				Frequency Time Curve (timed)
				of a Linear Frequency Sweep of a Square Wave
				RPM Time Curve of a rotational speed with a reciprocating deviation.
