![Multimeter](img/DDPViewer.jpg)
1. Display the value of a Derived Data Point (DDP) or User Defined Data
Point (UDDP) in a standalone window. Maximum 24 windows can be opened.
2.
Allow High-High, High, Low, Low-Low alarming. Alarm sounds can be
configured. Alarm acknowledgement is supported.
3. Displayed
precision can be specified.
4. Allow the user to define a UDDP
using mathematical expression. Various math functions are supported.
5. Support inter-frame processing including linear and exponential
averaging.
6. Support DDP Array Viewer which can be used to
generate the following reports: (1) Harmonic
Frequencies, RMS, Phase (2) Octave Bands, RMS
(3) Peak Frequencies, RMS, Phases (4) Frequency
Bands, RMS (5) Reverberation / Speech
Intelligibility (1/1 Octave) (6) Reverberation /
Speech Intelligibility (1/3 Octave)
7. Supports
Multilingual User Interface under Windows 2000, XP, Vista, 7, 8,
8.1, 10, 11 and
above. Currently supported languages are English, French, German,
Italian, Portuguese, Spanish, Russian, Simplified Chinese, Traditional
Chinese, Japanese and Korean.
Examples:
![Harmonic Decomposition](img/Multi-Instrument-DDP-Array-Viewer-Harmonics-m.png)
Report of Harmonic Frequencies, RMS, Phase
Report of Octave Bands, RMS
Report of Reverberation / Speech Intelligibility (1/1
Octave) based on Impulse Response
Report of Reverberation / Speech Intelligibility (1/3
Frequency Response Test with Pass / Fail Check on
Spectrum
Half Sine Shock Test with Pass / Fail Check on Waveform
Direct Display of Amplitude Modulation Index using User
Defined Data Point
Direct Display of Decoded DTMF Character using User
Defined Data Point |
