		1. Can measure the value of an inductor, a capacitor or a resistor, or
		the impedance of a network of them in a wide range and display the
		result in a big font.
  2. Two types of external connections are
		supported: serial connection for high impedance measurement, and
		parallel connection for low impedance measurement. Serial connection
		uses the sound card’s input impedance as reference, while parallel
		connection uses an external resistor of a relatively small value as
		reference.
  3. Support the calibration of the sound card input
		impedance which may vary with frequency.
  4. The value of the
		external reference resistor (if any) can be entered.
  5. The
		measurement
		range is displayed and updated when the relevant settings change.
		 6. The LCR Meter is a special Device Test Plan with built-in LCR
		measurement algorithm. The default LCR test plan uses 1 kHz sine wave as
		the test tone. However, you can configure your own LCR test plans (e.g.
		with different test tones) if necessary.
  7. Same as other Device
		Test Plan, the test results can be plotted in up to 8 X-Y plots. The
		variables for X and Y axes can be configured.
  8. Supports
		Multilingual User Interface under Windows 2000, XP, Vista, 7, 8,
		8.1, 10, 11
		and above. Currently supported languages are English, French, German,
		Italian, Portuguese, Spanish, Russian, Simplified Chinese, Traditional
		Chinese, Japanese and Korean.
				Inductance Measurement
				Capacitance Measurement
				Resistance Measurement
