![Sound Card Signal Generator](img/Scgen10a.jpg)
1. DAC Hardware Related Specifications
Sound Card Based Systems:
1) Bandwidth: 1 Hz - 200 kHz
(sound card dependent).
2) Maximum Output Voltage: about 2 V
3) Selectable sampling frequency (up to
768 kHz), sampling bit resolution (8, 16, 24 or 32 bits) and sampling
channels (one or two) (sound card dependent).
4) Support
calibration of the output channels.
Non
Please refer to the respective
hardware manual.
2. Support predefined waveforms: Sine,
Rectangle, Triangle and Saw Tooth. The duty cycle for a rectangle wave
is adjustable.
3. Support non-repetitive pink noise and white
noise generation. It is possible to generate identical or
different noises across channels.
4. Support multi-tones generation. A
Multi-Tones is a combination of predefined waveforms with different
amplitudes, frequencies, and phases. Pink noise and white noise with
specified amplitude can also be added into the multi-tones. Maximum 200
tones can be combined in each channel. In addition to the manual
configuration method, automatic configuration method is provided to
generate multitones that are aligned to FFT bands or fractional octave
bands within a specified frequency range. When the multitones are
aligned to FFT bands, it is possible to specify the signal's frequency
response: white noise (flat), pink noise (1/f) or arbitrary (a frequency
response file *.frf).
5. Support arbitrary
waveform generation through user defined waveform library. A waveform
library is a TXT file containing the coordinates of each point in one
cycle of the waveform. There is no limit as to how many points can be
used to define a waveform. Two types of libraries are supported:
Waveform Library and Bit Perfect Library.
6. Support Maximum Length Sequence
(MLS) generation. The length can be selected from 127 to 16777215.
7. Support Dual Tone Multi-Frequency (DTMF) generation.
8.
Support musical scale tone generation.
9. The predefined
waveform, multi-tones and user-defined waveform can be generated at a
frequency that sweeps linearly or logarithmically within a specified
frequency range and time duration.
10. The predefined waveform,
white noise, pink noise, multi-tones, user-defined waveform and MLS can
be generated at an amplitude that sweeps linearly or logarithmically
within a specified amplitude range and time duration. Option is
provided to allow a reverse sweep after a forward sweep.
11. Allow
specifying the phase difference between the two channels if the output
signals have the same frequency.
12. The amplitude of the output
signal is adjustable. Support Auto Ranging.
13. The generated signal can be saved as a
WAV file or a TXT file for a duration of up to 1000 s.
14. The
output signal can be looped back partially (i.e. only one channel while
the other channel can be used for field input) or fully (i.e. both
channels), via the software itself, to the input of the oscilloscope for
display and analysis in real time. Synchronized operation between the
Signal Generator and the Oscilloscope with a timing accuracy in the same
order of the sampling frequency is also supported. It is possible to
specify when to start the Oscilloscope after the Signal Generator is
started.
15. It is possible to add a mask with specified periodic
on/off timing to the signal to be output so that a burst-type signal can
be generated. You can choose whether to phase-lock each burst. The
mask can be specified as a window function in order to shape the
envelope of the output signal. It is also possible to specify the off/on
amplitude ratio.
16. Support fade in/out and modulation (AM, FM, PM) of the output signal.
17. Support DDS
mode for those devices that support DDS mode.
18. Support DC
offset adjustment for those devices that support it.
19. Supports
Multilingual User Interface under Windows 2000, XP, Vista, 7, 8,
8.1, 10, 11
and above. Currently supported languages are English, French, German,
Italian, Portuguese, Spanish, Russian, Simplified Chinese, Traditional
Chinese, Japanese and Korean.
![USB Signal Generator Sine](img/VT-USB-Signal-Generator-Sine-m.png)
Sine wave
![USB Signal Generator Square](img/VT-USB-Signal-Generator-Square-m.png)
Square Wave (duty cycle adjustable)
![USB Signal Generator Triangle](img/VT-USB-Signal-Generator-Triangle-m.png)
Triangle Wave
![USB Signal Generator Saw Tooth](img/VT-USB-Signal-Generator-Saw-Tooth-m.png)
Saw Tooth Wave
![USB Signal Generator Arbitrary](img/VT-USB-Signal-Generator-Arbitrary-m.png)
Arbitrary Wave
(user defined)
![USB Signal Generator Multi Tones](img/VT-USB-Signal-Generator-Multi-Tones-Octave-Band-Analysis-m.png)
Multi-Tones
Stimulating 32 1/3 Octave Bands at Their Centerline
Frequencies |
![USB Signal Generator White Noise Narrow Band Analysis](img/VT-USB-Signal-Generator-White-Noise-Narrow-Band-Analysis-m.png)
Narrow Band Spectrum Analysis of White Noise (flat)
![USB Signal Generator White Noise Octave Band Analysis](img/VT-USB-Signal-Generator-White-Noise-Octave-Band-Analysis-m.png)
Octave Band Spectrum Analysis of White Noise (+3dB/octave)
![USB Signal Generator Pink Noise Narrow Band Analysis](img/VT-USB-Signal-Generator-Pink-Noise-Narrow-Band-Analysis-m.png)
Narrow Band Spectrum Analysis of Pink Noise (-3dB/octave) |
![USB Signal Generator Pink Noise Octave Band Analysis](img/VT-USB-Signal-Generator-Pink-Noise-Octave-Band-Analysis-m.png)
Octave Band Spectrum Analysis of Pink Noise (flat)
Narrow
Band
Spectrum Analysis of MLS (flat)
![USB Signal Generator Fade In and Out](img/VT-USB-Signal-Generator-Signal-Fade-in-and-out-m.png)
Signal Fade In and Out
![USB Signal Generator Sine Burst](img/VT-USB-Signal-Generator-Sine-Burst-m.png)
Burst Signal (gated by Rectangle window)
![J-Test Signal for AES3 Jitter Test](img/VT-USB_Singal-Generator-JTEST_m.png)
J-TEST Signal for AES3 Jitter
Test |
![USB Signal Generator Frequency Sweep](img/VT-USB-Signal-Generator-Frequency-Sweep-m.png)
Frequeny Sweep (linear) with Narrow Band FFT
![USB Signal Generator Amplitude Sweep](img/VT-USB-Signal-Generator-Amplitude-Sweep-m.png)
Amplitude Sweep (linear) |
![Frequency Log Sweep](img/VT-USB-Signal-Generator-Frequency-Log-Sweep-m.png)
Frequeny Sweep (logarithmic) with Octave Analysis
![Multitone Phase Optimization to Minimize Crest Factor](img/VT-USB-Signal-Generator-MultiTones-Phase-Optimization-m.png)
Multitone Phase Optimization to Minimize Crest Factor (Before:
blue, After: red) |
![Periodic White Noise](img/VT-USB-Signal-Generator-Periodic-White-Noise-Narrow-Band-Analysis-m.png)
Multitone Periodic White Noise within Specified Frequency Range
(Narrow Band FFT)
![Periodic Pink Noise](img/VT-USB-Signal-Generator-Periodic-Pink-Noise-Octave-Band-Analysis-m.png)
Multitone Periodic Pink Noise within Specified Frequency Range
(Octave Analysis) |
![Multitone with Male Speech Spectrum](img/VT-USB-Signal-Generator-MultiTones-with-Arbitrary-Frequency-Response-Male-Speech-m.png)
Multitone with Aribrary Spectrum
(Male Speech as defined in IEC 60286-16)
![Multitone with RIAA Recording Response](img/VT-USB-Signal-Generator-MultiTones-with-Arbitrary-Frequency-Response-RIAA-Recording-m.png)
Multitone with Arbitrary Spectrum (RIAA Recording Response)
![Digital Filter Impulse Response and Bode Plot Measurement](img/Digital-Filter-Impulse-Response-and-Bode-Plot-Measurement-with-Impulse-m.png)
Digital Filter Impulse Response & Bode Plot Measurement using
Unit Impulse Signal
![Jitter Measurement using J-TEST signal](img/Jitter-Measurement-with-J-TEST-signal-m.png)
Jitter Measurement using J-TEST Signal
![Digital Filter Step Response Measurement](img/Digital-Filter-Step-Response-Measurement-with-Step-m.png)
Digital Filter Step Response Measurement using
Unit Step Signal
![ANSI / CEA-2010 Subwoofer Peak SPL Test](img/ANSI-CEA-2010-Subwoofer-Peak-SPL-Test-m.png)
ANSI / CEA-2010 Subwoofer Peak SPL Test using a 6.5-cycle Hann
Windowed Sine Burst |
![Band Limited Pink Noise](img/VT-USB-Signal-Generator-Periodic-Band-Limited-Pink-Noise-Octave-Band-Analysis-m.png)
Multitone Periodic Band Limited Pink Noise under Octave Analysis
![Single Channel Transfer Function Measurement Loopback Mode](img/VT-USB-Signal-Generator-Single-Channel-Transfer-Function-Measurement-Loopback-Mode-m.png)
Impulse Response Measured with Single Field Input under Partial
Loopback Mode (iB=oA)
![Amplitude Modulation Signal Generation](img/VT-USB-Signal-Generator-Amplitude-Modulation-m.png)
Generation of a Amplitude Modulation Signal
![Frequency Modulation Signal Generation](img/VT-USB-Signal-Generator-Frequency-Modulation-m.png)
Generation of a Frequency Modulation Signal
![Phase Modulation Signal Generation](img/VT-USB-Signal-Generator-Phase-Modulation-m.png)
Generation of a Phase Modulation Signal
![Generation of Periodic Signal with DC Offset](img/VT-USB-Signal-Generator-Periodic-Signal-with-DC-Offset-m.png)
Generation of a Periodic Signal with a DC offset
