		 1. Support Waterfall Plot and Spectrogram.  It can be generated by multiple frames of data (Inter-frame Mode) or one single frame of data (Intra-frame mode). The former supports Short Time Fourier Transform (STFT) only while the latter supports both STFT and Cumulative Spectral Decay (CSD).
		2. For Waterfall Plot, the tilt angle of T axis and the height
		percentage of Y axis are adjustable. Six color palettes are available:
		No Color, Rainbow, Bluish, Yellowish, Grayscale, Inverted Grayscale.
		 3. For Spectrogram, five color palettes are available: Rainbow,
		Bluish, Yellowish, Grayscale, Inverted Grayscale.  A smoothing
		option is provided.
  4. X axis can
		be displayed in linear, logarithmic, or 1/1 ~ 1/96 octave scale.
  5. Y axis is
		displayed in absolute mode in RMS Voltage, dBV, dBu, dBSPL or dBFS.
		 6. Number of spectral profiles can be set from 10 to 200.
  7.
		Spectral profiles are time stamped with an accuracy in 1 ms.
		8. A 3D cursor reader can be used to display the X, Y, T readings of an
		actual measurement point.  The X-Y profile at that point is highlighted
		and also displayed in a separate X-Y plot.
  9. The data in the
		graph can be copied into the clipboard as text and later paste into
		other software such as Microsoft Excel for further analysis. The image
		of the graph can be copied into the clipboard as Bitmap image and later
		paste into other software such as Microsoft Word.
  10. Analysis
		results can be exported as TXT files. The 3D data can be sliced by
		either time or frequency.
  11. Data curves can be
		print-previewed, printed out directly or saved as BMP files.
  12.
		Independent X axis and Y axis zooming.
  13. Supports
		Multilingual User Interface under Windows 2000, XP, Vista, 7, 8,
		8.1, 10, 11
		and above. Currently supported languages are English, French, German,
		Italian, Portuguese, Spanish, Russian, Simplified Chinese, Traditional
		Chinese, Japanese and Korean.
				Waterfall Plot
				Waterfall Plot with 3D cursor reader
				Spectrogram
				Spectrogram with 3D cursor reader
				Inter-frame Mode of
				Spectrum 3D Plot (Short-Time Fourier Transform)
				Intra-frame Mode of Spectrum 3D Plot (Short-Time Fourier
				Transform)
				Intra-frame Mode of Spectrum 3D Plot (Cumulative Spectral Decay)
				Spectrogram Smoothing
				Reverberation Analysis using Waterfall Plot (Intra-frame Mode)
				Cumulative Spectral Decay of Impulse Response (Intra-frame Mode)
