		1. Seven view types: Real time Amplitude Spectrum, Real time Phase
		Spectrum, Real time Auto Correlation Function, Real time Cross
		Correlation Function, Real time Coherence
		/ Non-Coherence
		Function, Real time Transfer
		Function / Impedance Analyzer, Real time Impulse Response.
  2. Independent X axis and Y
		axis zooming and scrolling.
  3. In Amplitude Spectrum, Y axis
		supports relative modes in linear and dBr scale, and absolute mode in
		RMS voltage, dBV, dBu, dB, dBFS scale. X axis supports linear,
		logarithmic and octave scale (1/1, 1/3, 1/6, 1/12, 1/24, 1/48, 1/96).
		Support amplitude / power spectrum density display.  Y axis can be converted to
		impedance display.
		 4. Analysis results can be exported as TXT files.
  5. Data
		curve can be print-previewed, printed out directly or saved as BMP files.
  6. Fast
		display refresh rate: about 50 frames per second (tested with a sound
		card under Windows XP SP2 on IBM ThinkPad R51 Laptop PC with Intel
		Pentium M processor 1.60 GHz, with scan time=10 ms and FFT size=1024 and
		both the Oscilloscope and the Spectrum Analyzer running under "Auto"
		mode). Thus data are displayed and analyzed in "true" real time.
		7. The colors of display, font size, screen refresh rate are
		configurable.
  8. FFT size can be adjusted from 128 to 4194304
		points.
  9. Allow record length to be different from FFT size. If
		the FFT size is greater than the record length, then zero(s) will be
		added at the end of the actual measurement data during FFT computation.
		If the FFT size is less than the record length, then the measurement
		data will be split into different segments with the size of each segment
		equal to the FFT size. Segment overlap percentage can be selected in the
		range of
		0%~99.9%. The final result will be obtained by averaging the
		FFT results from all segments.
  10. Support 69 window functions:
		Rectangle, Triangle (or Fejer), Hann, Hamming, Blackman, Exact
		Blackman, Blackman Harris, Blackman Nuttall, Flat Top, Exponential,
		Gaussian, Welch (or Riesz), Cosine, Riemann (or Lanczos), Parzen, Tukey,
		Bohman, Poisson, Hann-Poisson, Cauchy, Bartlett-Hann, Kaiser, etc.
		 11. Display peak frequency with sub-FFT-bin-size accuracy in
		Amplitude Spectrum display, second peak time delay and corresponding
		coefficient in Auto Correlation Function display, peak time delay and corresponding
		coefficient in Cross Correlation Function display, peak frequency and
		corresponding coefficient in Coherence Function display, peak frequency
		and corresponding gain and phase in Transfer Function display, peak time
		and corresponding value in Impulse Response display.
  12. Allow
		the measurement of Total Harmonic Distortion (THD), THD+Noise (THD+N),
		Signal in Noise and Distortion (SINAD), Signal-to-Noise Ratio (SNR) and
		Noise Level (NL), Total Non-Coherent Distortion+Noise (TNCD), and GedLee
		Metric in a specified frequency range.
  13. Allow the
		measurement of IMD-SMPTE/DIN, IMD-CCIF2, IMD-CCIF3, DIM, Crosstalk, Bandwidth
		(-3dB), Harmonics, Energy in user defined frequency bands, Peaks, Total
		Distortion+Noise (TD+N), Wow &
		Flutter, sound loudness, loudness level & sharpness & articulation
		index.
		 14. In THD measurement and harmonics analysis, the fundamental frequency can be
detected automatically based on the peak frequency or another variable
such as the RPM reading from a tachometer (e.g. for the purpose of order
tracking). It can also be specified manually.
  15. Support one cursor reader and two markers which stick to the
		measurement data.  Support peak markers.
  16. Intra-frame processing includes: Remove DC
		Component, Frequency Compensation, Frequency Weighting (flat, A
		weighting, B weighting , C weighting, ITU-R 468 weighting), and Smooth
		via Moving Average (linear or octave).  Frequency compensation is achieved via loading a
		user configurable text-based Frequency Compensation File (*.fcf).
		 17. Four inter-frame processing methods: None, Peak Hold, Linear
		Average, Exponential Average. The number of frames (2~200, forever) for
		peak hold or linear averaging can be specified. The process can be reset
		during runtime if “forever” is chosen.
  18. Five chart types: Line,
		Scatter, Column, Bar, and Step. Line width is adjustable.
  19. Up
		to five reference curves can be set for each channel. The reference
		curve can be configured by either copying the current curve, or loading
		a properly formatted text file or a previously saved reference file from
		the hard disk.  Reference curves can be assigned as High-High,
		High, Low, Low-Low limits.
  20. The data in the graph can be copied into the
		clipboard as text and later paste into other software such as Microsoft
		Excel for further analysis. The image of the graph can be copied into
		the clipboard as Bitmap image and later paste into other software such
		as Microsoft Word.
  21. Supports Multilingual User Interface under
		Windows 2000, XP, Vista, 7, 8, 8.1, 10, 11 and above. Currently supported
		languages are English, French, German, Italian, Portuguese, Spanish,
		Russian, Simplified Chinese, Traditional Chinese, Japanese and Korean.
				Measurement of THD, THD+N, SNR, SINAD, ENOB...
				Measurement of IMD (SMPTE)
				Measurement of Crosstalk
				Measurement of Frequency Response (white noise stimulation)
				Fast Measurement of Frequency Response (multi-tone stimulation)
				Measurement of Frequency Response (pink noise stimulation + octave
				analysis)
				Impact Test
				Normalized Amplitude Spectrum of a Signal
				Auto Correlation of a Sinewave
				Cross Correlation of a Sinewave and Its Phase Shifted Copy
				Phase Spectrum of a Sinewave and Its Phase Shifted Copy   |
				Spectrum of Kaiser 6 Window Function
				Measurement of
				Coherence Function between Output and Input (white noise
				stimulation)   |
				Bode Plot measured via Dual Channel FFT (white noise
				stimulation)
				Impulse Response measured via Dual-Channel FFT (white noise
				stimulation)   |
				GedLee Metric for Perception Based Nonlinear Distortion
				Measurement
				Measurement of Total Non Coherent Distortion + Noise (two
				independent white noises)   |
				Measurement of Total Distortion + Noise (multitone stimulation)
				Measurement of
				IMD (CCIF2)   |
				Sound Quality (Loundness, Loundness Level, Sharpness,
				Articulation Index) measurement
				Comparison between a distorted sine wave and its 2nd & 3rd
				harmonics residual  (obtained by a 1022-order band-pass FIR
				digital filter)   |
				Impedance & Phase vs Frequency of a Speaker (pink noise stimulation)
				Time Delay Measurement using Cross Correlation (white noise
				stimulation)   |
				Time Delay Measurement using Generalized Cross Correlation
				(music stimulation)
				Time Delay and Well depth Measurement using Auto Correlation (MLS
				stimulation)   |
				Dynamic Intermodulation (DIM) Distortion Measurement
				Wow & Flutter Measurement   |
				Measurement of Frequency Response (logarithmic sweep + octave
				analysis)
				Measurement of
				Phase Difference between Two Sinewaves   |
				Harmonic Analysis and Signal Decomposition
				Comparison between a sine wave with clipping distortion and its
				distortion residual (fundamental removed by a 1022-order band-stop FIR
				digital filter)   |
				Comparison between a sine wave with crossover distortion and its
				distortion residual (Simulated, fundamental removed by a
				1022-order band-stop FIR digital filter)
				Impedance & Phase vs Frequency of a filter using swept sine from
				50kHz to 100kHz with DSO-2A20E |
				Measurement of THD, THD+N, SNR, SINAD, ENOB of a 1kHz Sinewave Generated Digitally Through the MultiTone Function with No Spectral Leakage
