Model CA-YD |
Sensitivity ± 5%
(mV/g) |
Frequency Response
±5% (Hz) |
Operating Range
(g) |
Shock Limit (g) |
Weight (gram) |
Size (mm) |
Mounting |
Datasheet |
Unit Price
Free Express Shipping |
General-Purpose |
 160 |
100 |
0.5~8k |
50 |
2000 |
6.5 |
Φ11×14 |
Adhensive |
US$299.95
 191 |
100 |
1~8k |
50 |
5000 |
8 |
12×12×12 |
Adhensive |
US$349.95
 180 |
1 |
1~12k |
5000 |
5000 |
10 |
Φ14×25 |
M5 |
US$229.95
 181 |
10 |
1~10k |
500 |
3000 |
11 |
Φ14×20 |
M5 |
US$229.95
 181-10
(1181) |
100 |
1~10k |
50 |
3000 |
11 |
Φ14×20 |
M5 |
US$264.95
 182 |
20 |
1~10k |
250 |
3000 |
9 |
Φ13×21 |
M5 |
US$229.95
 182-10
(1182) |
100 |
1~10k |
50 |
3000 |
11 |
Φ13×21 |
M5 |
US$264.95
 185 |
50 |
0.5~5k |
100 |
2000 |
25 |
Φ18×26 |
M5 |
US$199.95
 186 |
100 |
0.5~5k |
50 |
2000 |
30 |
Φ18×30 |
M5 |
US$199.95
 188 |
500 |
0.3~2.5k |
10 |
1000 |
100 |
Φ30×28 |
M5 |
US$229.95
 189 |
1000 |
0.2~1k |
5 |
500 |
210 |
Φ38×35 |
M8 |
US$279.95
Industrial Monitoring
(Isolated)
183 |
25 |
1~6k |
200 |
2000 |
165 |
60×42×30 |
M6 |
US$289.95
185T |
50 |
0.5~5k |
100 |
2000 |
35 |
Φ18×32 |
M5 |
US$209.95
186G |
100 |
1~5k |
50 |
3000 |
65 |
Φ20×44 |
M6 |
US$244.95
187T |
100 |
1~5k |
50 |
3000 |
80 |
Φ25×52 |
1/4-28 UNF |
US$229.95
187T02 |
100 |
1~10k |
50 |
3000 |
52 |
Φ20×46 |
1/4-28 UNF |
US$229.95
187C |
100 |
1~5k |
50 |
3000 |
110 |
22×22×53 |
M6 Through Hole |
US$229.95
187C01 |
100 |
1~7k |
50 |
2000 |
73 |
21×18×46 |
M6 Through Hole |
US$244.95
188T |
500 |
0.6~5k |
10 |
2000 |
90 |
Φ25×52 |
1/4-28 |
US$259.95
188C |
500 |
0.5~5k |
10 |
2000 |
132 |
23×25×53 |
M6 Through Hole |
US$259.95
188G |
500 |
0.3~3k |
10 |
2000 |
90 |
Φ25×48 |
M5 |
US$259.95
188GF (Explosion-Proof) |
500 |
0.3~3k |
10 |
2000 |
90 |
Φ25×48 |
M5 |
US$349.95
18T9LF |
1000 |
0.25~500 |
5 |
1000 |
140 |
Φ28.5 ×59.5 |
1/4-28 to M6 |
US$239.95
Tri-Axial
3152 |
20 |
1~4k |
250 |
1000 |
28 |
25×25×13 |
Φ5 Through Hole |
US$549.95
3153
1 |
1~8k |
5000 |
5000 |
10 |
14×14×14 |
M5 |
US$699.95
3177-500
500 |
1~4k |
10 |
3000 |
220 |
42×42×23 |
2×Φ6.1 Through Hole |
US$799.95
3193 3193-5 3193-10
10 50 100 |
1~4k |
500 100 50 |
2000 |
32 |
20×20×20 |
M5 |
US$699.95
| 2. IEPE Velocity Sensors
CV-YD Series |
Model CV-YD |
Sensitivity ± 5%
(mV/(mm/s)) |
Frequency Response
± 3dB (Hz) |
Operating Range
(mm/s) |
Shock Limit (g) |
Weight (gram) |
Size (mm) |
Mounting |
Datasheet |
Unit Price
021 |
4 |
4~4k |
1000 |
3000 |
80 |
Φ22×59 |
1/4-28 UNF |
US$264.95
| 3. IEPE Force Sensors
CL-YD Series |
Model CL-YD |
Sensitivity ± 5%
(mV/N) |
Operating Range
(N) |
Weight (gram) |
Size (mm) |
Mounting |
Datasheet |
Unit Price
Unidirectional |
1005AE |
1 |
0~5000 |
14 |
Φ16×8 |
Adhesive or
fixture |
US$314.95
1005E |
1 |
0~5000 |
10 |
Φ14.5×7.5 |
Φ6 through hole |
US$429.95
1015E |
0.3 |
0~15000 |
10 |
Φ14.5×7.5 |
Φ6 through hole |
US$489.95
1035E |
0.143 |
0~35000 |
25 |
Φ23.8×10 |
Φ10 through hole |
US$529.95
1060E |
0.083 |
0~60000 |
34 |
Φ28.5×11.5 |
Φ13 through hole |
US$584.95
1100E |
0.05 |
0~100000 |
95 |
Φ43×14 |
Φ20 through hole |
US$699.95
1200E |
0.025 |
0~200000 |
140 |
Φ52.5×15 |
Φ26.5 through hole |
US$839.95
1300E |
0.0167 |
0~300000 |
370 |
Φ70×20 |
Φ27 through hole |
US$1089.95
1400E |
0.0125 |
0~400000 |
400 |
Φ80×20 |
Φ34 through hole |
US$1419.95
1600E |
0.0083 |
0~600000 |
750 |
Φ95×23 |
Φ40.5 through hole |
US$1689.95
11000E |
0.005 |
0~1000000 |
2200 |
Φ145×28 |
Φ66 through hole |
Contact Us
12000E |
0.0025 |
0~2000000 |
3000 |
Φ170×36 |
Φ66 through hole |
Contact Us
Bidirectional |
2000E |
10 |
±500 |
17 |
Φ16×17.5 |
M5 |
US$449.95
2001E |
5 |
±1000 |
17 |
Φ16×17.5 |
M5 |
US$474.95
2002E |
2.5 |
±2000 |
17 |
Φ16×17.5 |
M5 |
US$499.95
2005E |
1 |
±5000 |
17 |
Φ16×17.5 |
M5 |
US$524.95
2010E |
0.5 |
±10000 |
150 |
Φ26×48 |
M12 |
US$699.95
2030E |
0.166 |
±30000 |
195 |
Φ29×51 |
M16 |
US$799.95
2050E |
0.1 |
±50000 |
700 |
Φ43×74 |
M20 |
US$999.95
2060E |
0.083 |
±60000 |
1150 |
Φ53×84 |
M24 |
US$1399.95
| 4. IEPE Impedance
Heads |
CL-YD-332 |
Force Sensor
Sensitivity: 5 mV/N; Range: ±1000 N; Frequency Response: 0.3
Hz~10 kHz
Accelerometer: Sensitivity: 50 mV/g;
Range: 100 g; Frequency Response: 1 Hz ~ 8 kHz |
US$549.95
| 5. IEPE Impact
Hammers |
LC-00KE |
Measurement
Range: 200 N; Sensitivity: 25 mV/N |
US$529.95
LC-01KE |
Measurement
Range: 2 kN; Sensitivity: 2.5 mV/N |
US$529.95
LC-02KE |
Measurement
Range: 5 kN; Sensitivity: 1 mV/N |
US$629.95
LC-03KE |
Measurement
Range: 30 kN; Sensitivity: 0.167 mV/N |
US$749.95
LC-04KE |
Measurement
Range: 60 kN; Sensitivity: 0.083 mV/N |
US$799.95
| 6. IEPE Simulator |
YE8480 |
YE8480 is a low-noise unit-gain IEPE
simulator that simulates the behavior of an IEPE sensor
accurately. When used in conjunction with a signal generator, it
can be used in place of an IEPE sensor to calibrate or test IEPE
signal conditioners.
US$349.95
| 7. Magnetic
Mounting Bases |
Mouting thread: 1/4-28 UNF, Size: Φ30×12 mm, Weight:
52g, Magnetic Force: 200N, Max. Acceleration: 300g |
US$49.95
Mounting thread: M5, Size: Φ30×12 mm, Weight:
US$49.95
| 8. IEPE Microphones
and Sound Intensity Probes |
IEPE-MIC-14604A |
IEPE-MIC-14604A is a 1/2" IEC 61094-4 Class 1 free-field IEPE
measurement microphone. It meets the stringent standards not
found in consumer or even professional audio products.
US$499.95
IEPE-MIC-14604B |
IEPE-MIC-14604B is a 1/2" IEC 61094-4 pressure-field IEPE measurement microphone. It meets the stringent standards not found in consumer or even professional audio products.
US$449.95
IEPE-SIP-8450 |
IEPE-SIP-8450 is a dual-microphone sound intensity probe designed in accordance with IEC 61043 Class 2. It includes two 1/2" prepolarized measurement condenser microphones in a face-to-face configuration, along with their preamplifiers featuring IEPE interfaces, all precisely phase-matched.
US$2899.95
9. Sound Level
Calibrators |
SPL-CAL-6021A |
SPL-CAL-6021A sound level
calibrator is an IEC 60942: 2017 compliant, Class 1, portable,
battery powered sound source suitable for calibration of 1", 1/2" and 1/4"
measuring microphone. It features a very stable output sound pressure
level through a negative feedback control loop.
US$519.95
SPL-CAL-6022A |
SPL-CAL-6022A sound level calibrator is an IEC 60942: 2017 compliant, Class 2, portable, battery powered sound source suitable for
calibration of 1", 1/2" and 1/4" measuring microphones. It features automatic atmospheric pressure compensation and thus no manual compensation is needed.
US$249.95
SPL-CAL-6223F
SPL-CAL-6223F multi-frequency sound level calibrator is an IEC 60942: 2017 compliant, Class 1, portable, rechargeable battery powered sound source suitable for calibration of 1", 1/2" and 1/4" measuring microphones. It has built-in temperature, humidity and barometric pressure sensors and can display their measured values as well. It is able to
automatically compensate for temperature and atmospheric
pressure variation.
US$669.95
| 10. Vibration
Calibrators |
VIB-CAL-606 |
The Handheld vibration calibrator
VIB-CAL-606 is a small, self-contained handheld shaker
designed for quick and easy checking of accelerometers and
vibration measurement systems, providing a known and
controlled RMS vibration for verification of accelerometers
weighing up to 150g (including cable).
US$599.95
