PC based USB 8~16Bit 100MSPS 40MHz Oscilloscope, Spectrum Analyzer, 10-bit
				200MSPS 60MHz
				AWG Signal Generator        Brochure      Manual
				US$349.95
				Free Express
				Shipping
				 This is one of the second-generation USB DSOs
				(USB oscilloscopes) designed and developed by Virtins Technology. This generation of USB DSOs features Virtins Technology’s unique hardware-based DSP algorithm which enhances the performance and functionality dramatically without adding extra hardware cost. When used in conjunction with Multi-Instrument® software, the USB DSO converts any desktop, laptop, or tablet PC into a powerful oscilloscope, spectrum analyzer, multimeter, data logger, signal generator and so forth, all of which work simultaneously.
				 1) VT DSO-2810E unit with a hardware bundled
				Multi-Instrument
				Standard software license 2) 2 × 60MHz Oscilloscope Probe
				P2060 with two switchable positions: × 1, × 10 3) Signal
				Generator Test Lead (1 m)  4) USB cable (1.5 m)  5) CD
				(contains the copy-protected Multi-Instrument Software and VT
				DSO-2810E driver)  6) Individual voltage calibration data
		3.
		VT DSO-2810E Hardware Specifications
				| Oscilloscope Horizontal
				(Time) Axis  |
				| Real Time Sampling
				Frequency (fs) |
				Single Analog Channel 100 MHz
				Single or Dual Analog Channels with
				or without 1-bit Digital Channel 50 MHz, 40 MHz, 20
				MHz, 10 MHz, 5 MHz, 4 MHz, 2 MHz, 1 MHz, 500 kHz, 400 kHz,
				200 kHz, 100 kHz, 50 kHz, 40 kHz, 20 kHz, 10 kHz, 5 kHz, 4
				kHz, 2 kHz, 1 kHz, 500 Hz, 400 Hz, 200 Hz, 100 Hz, 50 Hz, 40
				Hz, 20 Hz, 10 Hz, 5 Hz, 4 Hz, 2 Hz, 1 Hz |
				| Equivalent Sampling
				Frequency |
				= [Real Time Sampling
				Frequency] × [Number of Frames Persisted]. Maximum 20 GHz, for
				repetitive signals whose maximum frequency is less than ¼ of the
				real time sampling frequency. Not valid for the case of
				post-trigger. |
				| Buffer Size |
				Normal Frame Mode |
				Analog |
				Single
				Channel 40000 samples (8 bits) 20000 samples (16 bits)
				Dual Channels 20000 samples / channel (8 bits, Non-ALT
				mode)  10000 samples /
				channel (16 bits, Non-ALT mode) 40000 samples / channel (8
				bits, ALT mode) 20000 samples / channel (16 bits, ALT mode) |
				| Digital |
				20000 samples (1 bit) |
				Record Mode (Streaming Mode) |
				Limited only by hard disk
				space available and maximum file size allowed by the operating
				system. Maximum sampling frequency for continuous streaming
				is computer speed and software setting dependent and typically
				10
				MHz (single channel, 8 bit) in Multi-Instrument. |
				Roll Mode (Streaming Mode for Low
				Frequency Signals) |
				Limited only by the
				computer memory available. Roll Mode is allowed when fs
				≤ 1MHz and [Record Length]
				≥ 4 × [Roll Width]. Maximum sampling
				frequency for continuous streaming is computer speed and
				software setting dependent. |
				| Sweep Time |
				10 ns ~ 500 s
				(Non-Streaming Mode) |
				| Sampling Frequency Accuracy |
				± 50 ppm |
				| Oscilloscope Vertical
				(Analog) Axes |
				| Number of Channels |
				2 (i.e. Ch. A and Ch. B) |
				| ADC Bit Resolution |
				8 Bits |
				(available only when Sampling Frequency is less than 40 MHz) |
				16 Bits If this option
				is selected, the effective bit resolution increases from 8 bits
				to up to 16 bits as the sampling frequency goes down.
				(Assuming white noise in the signal) |
				| Sampling Frequency |
				Effective Bit Resolution |
				| ≥ 40 MHz |
				8 Bits |
				≤ 10 MHz |
				9 Bits |
				| ≤ 2.5 MHz |
				10 Bits |
				≤ 625 kHz |
				11 Bits |
				| ≤ 156 kHz |
				12 Bits |
				≤ 39 kHz |
				13 Bits |
				| ≤ 9.8 kHz |
				14 Bits |
				≤ 2.4 kHz |
				15 Bits |
				| ≤ 610 Hz |
				16 Bits |
				| Bandwidth |
				fs > 20 MHz |
				40 MHz |
				| fs ≤ 20 MHz |
				8 Bits |
				No Effective Bit Resolution
				Enhancement |
				40 MHz |
				Enhancement |
				6 ~ 10 MHz |
				| 16 Bits |
				Enhancement |
				about 0.443 fs |
				(Full Scale) |
				± 10 mV, ± 20 mV, ± 50 mV,
				± 100 mV, ± 200 mV, ± 500 mV, ± 1 V, ± 2 V, ± 5 V, ± 10 V, ± 20
				V, ± 50 V |
				| Max. Allowed Voltage |
				± 100 V (DC + AC peak), derated above 100kHz |
				| DC Accuracy |
				± 1% |
				| Coupling Type |
				AC / DC |
				| Input Isolation |
				No (Isolation can be
				achieved through a USB isolator) |
				| Terminal Type |
				Referenced Single-Ended,
				BNC |
				| Input Impedance |
				1 MΩ , 15 pF |
				| Zero Calibration |
				Through hardware.
				Individually done at factory, user adjustable |
				| Gain Calibration |
				Through hardware.
				(Digital) Axis |
				1 (i.e. External Trigger Channel, 1-bit
				ADC) |
				| Bandwidth |
				140 MHz |
				| Threshold Resolution |
				45 mV |
				| Threshold Hysteresis |
				225 mV |
				| Threshold Range |
				± 20 V |
				± 100V
				| Threshold DC Accuracy |
				± 1% |
				| Coupling Type |
				DC |
				| Input Isolation |
				No (Isolation can be achieved through a
				USB isolator) |
				| Terminal Type |
				Referenced Single-Ended, BNC |
				| Input Impedance |
				1 MΩ , 15 pF |
				| Zero Calibration |
				Through software. Individually done at
				factory. |
				| Gain Calibration |
				factory. |
				Oscilloscope Trigger |
				| Trigger Detection Method |
				Digital |
				| Trigger Source |
				Ch. A, Ch. B, EXT, ALT |
				| Trigger Mode |
				Auto, Normal, Single, Slow |
				| Trigger Edge |
				Rising, Falling |
				| Trigger Level |
				Adjustable within full scale |
				| Pre-Trigger |
				-100% ~ 0% of Record Length |
				| Post-Trigger |
				0 ~ 100% of Record Length |
				| Trigger Frequency Rejection |
				Nil: No Rejection HFR: High
				Frequency Rejection, cut off at 0.11fs NR0: Noise Rejection,
				hysteresis = 1% of half of full scale NR1: Noise Rejection,
				hysteresis = 2% of half of full scale NR2: Noise Rejection,
				hysteresis = 4% of half of full scale NR3: Noise Rejection,
				hysteresis = 8% of half of full scale NR4: Noise Rejection,
				hysteresis = 16% of half of full scale HN0: HFR + NR0 HN1:
				HFR + NR1 HN2: HFR + NR2 HN3: HFR + NR3 HN4: HFR + NR4
				HNX: selectable HFR + adjustable hysteresis = 0% ~ 25% of half
				of full scale Note: The specified hysteresis may be modified
				internally to ensure [Trigger Level (%)] – [Hysteresis (%)] ≥ -100% at rising edge, or [Trigger Level (%)] + [Hysteresis (%)] ≤ 100% at falling edge. |
				Oscilloscope Dynamic
				Performance (Typical) |
				| THD |
				fs=100 kHz, f=1 kHz, from 2nd to 20th
				order, full-scale input: 8 bits (without bit resolution
				enhancement):
				≤ -55 dB 8 bits (with bit resolution enhancement):
				≤ -56 dB 16 bits:
				≤ -59 dB |
				| IMD (250 Hz + 8 kHz, 4:1) |
				fs=100 kHz, from 2nd to 3rd order,
				full-scale input: 8 bits (without bit resolution enhancement):
				≤ -51 dB 8 bits (with bit resolution enhancement):
				≤ -52 dB 16 bits: ≤ -57 dB |
				| IMD (19 kHz +20 kHz, 1:1) |
				fs=100 kHz, 2nd order only, full-scale
				≤ -65 dB 8 bits (with bit resolution enhancement):
				≤ -65 dB 16 bits:
				≤ -78 dB |
				| SFDR |
				fs=100 kHz, f=1 kHz, full-scale input:
				≥ 61 dB 8 bits (with bit resolution enhancement):
				≥ 61 dB 16 bits:
				≥ 62 dB |
				| Crosstalk |
				≤ -45 dB (at the same voltage measuring range for full
				bandwidth) |
				| Noise |
				For voltage measuring ranges ± 50 mV
				and above: 8 bits (without bit resolution enhancement):
				≤ ± 3 counts (± 1%)  8 bits (with bit resolution
				enhancement, fs =100 kHz):
				≤ ± 2 counts (± 0.8%)  16 bits (fs =100 kHz):
				≤ ± 0.3 8-bit count (± 0.1%)  For voltage measuring
				ranges ± 10 mV and ± 20 mV: 8 bits (without bit resolution
				enhancement):
				≤ ± 15 counts (± 6%)  8 bits (with bit resolution
				≤ ± 9 counts (± 4%)  16 bits (fs =100 kHz):
				≤ ± 1  8-bit count (± 0.4%) |
				1 |
				| Coupling Type |
				DC |
				Output Isolation |
				No |
				| Terminal Type |
				| Output Impedance |
				50 Ω |
				| Overvoltage
				Protection |
				± 35 V |
				Signal Generator -Analog
				(when Signal Generator is running) |
				| Output Voltage Range |
				± 2 V, adjustable |
				| DAC Bit Resolution |
				10 Bits |
				| Output Sampling Frequency
				(fs) |
				DDS Mode
				200 MHz, 100MHz, 50MHz     DDS Mode or Streaming
				Mode
				20MHz, 10MHz, 5MHz, 2 MHz, 1 MHz, 500 kHz, 200 kHz, 100 kHz, 50 kHz,
				20 kHz, 10 kHz, 5 kHz |
				Accuracy |
				± 50 ppm |
				| Bandwidth |
				DC ~ 60 MHz |
				| Output Signal Frequency |
				0 ~ ½ of output sampling frequency |
				| Rise Time (10% ~ 90%) |
				< 5.8 ns |
				| DC Offset Range |
				Full output voltage range |
				| DC Accuracy |
				± 0.5% of full scale |
				| Waveform |
				DDS Mode* |
				Sine, Rectangle (duty cycle
				adjustable), Triangle, Saw Tooth, White Noise, MLS (length =
				263-1), User
				Configurable Waveform Library (Arbitrary), Musical Scale |
				| Streaming Mode* |
				adjustable), Triangle, Saw Tooth, White Noise, Pink Noise,
				MultiTones, MLS (127~16777215), DTMF, User Configurable Waveform
				DDS Mode |
				<0.05 Hz (fs = 200 MHz) <0.000001 Hz
				(fs = 5 kHz) |
				| Streaming Mode |
				Virtually infinitesimal |
				| Buffer Size |
				DDS Mode |
				Without interpolation: 1024 samples
				With interpolation: 1024 × 65536 = 67108864 samples (Note:
				interpolation is only available when fs <= 100 MHz) |
				| Streaming Mode |
				Virtually unlimited |
				| Frequency Sweep |
				DDS Mode |
				Supports linear sweep of all types of
				repetitive waveforms. Sweep speed range: 1/32768 × fs2
				/ 232 ~ 65535 × fs2 / 232
				(e.g. 284 Hz/s ~ 610 GHz/s when fs = 200 MHz) |
				| Streaming Mode |
				Supports linear and logarithmic sweep
				of all types of repetitive waveforms. Sweep speed range:
				unlimited |
				| Amplitude Sweep |
				DDS Mode |
				waveforms. Sweep speed range: 1/32768 × fs / (232 –1) ~
				65535 × fs / (232 –1)
				(e.g. 0.000142 %/s ~ 305171%/s when fs = 200 MHz) |
				| Streaming Mode |
				of all types of waveforms. Sweep speed range: unlimited |
				| Duration (Signal Length)
				Resolution |
				DDS Mode |
				1/fs or 1µs, whichever is greater |
				| Streaming Mode |
				1/fs |
				| THD |
				≤ -60 dB (fs = 2 MHz, f = 1 kHz, from 2nd to 20th
				order, full-scale output) |
				| SFDR |
				 ≥	65 dB (fs = 2 MHz, f = 1 kHz, full-scale output) |
				| Zero Calibration |
				factory. |
				| Gain Calibration |
				factory. |
		*DDS mode consumes almost no computer CPU time while streaming mode
		consumes a lot. Maximum sampling frequency for continuous streaming is
		computer speed and software setting dependent and typically 10 MHz
		in Multi-Instrument. More advanced functions are provided via
		Multi-Instrument software under streaming mode. Please refer to
		Multi-Instrument software manual for details.
				Signal Generator - Digital
				(when Signal Generator is not running) |
				| Voltage Range |
				-1.65 ~ 1.65 V, not adjustable |
				Accuracy |
				± 50 ppm |
				| Bandwidth |
				60 MHz |
				< 5.8 ns |
				| Waveform |
				Square |
				Signal Frequency |
				25 MHz / N, (N=1, 2, 3, ….25000) |
				| MLS |
				General |
				| Interface |
				USB 2.0 High Speed / USB
				1.1 Full Speed / USB Isolator |
				| Device Category in
				Multi-Instrument |
				ADC Device |
				VT DAQ 1 |
				| DAC Device |
				VT DAO 1 |
				| Firmware Upgradable |
				Yes |
				| Power |
				Bus powered by USB port, no
				external power source required. |
				| Power Consumption |
				Max. 2.5W |
				| Dimensions |
				145 mm (L) × 108 mm (W) ×
				26 mm (H),   anodized aluminum case |
				| System Requirement |
				Windows XP, Vista, 7, 8,
				8.1, 10 or
				11, 32 bit or 64 bit |
				| Operating Temperature |
				0° C ~50° C |
		4. P2060 Oscilloscope Probe Hardware
				| Attenuation Ratio |
				× 1, × 10 |
				| Bandwidth |
				DC ~ 60 MHz (× 10), DC ~ 6 MHz (× 1) |
				| Input Impedance |
				1 MΩ (× 1, with VT DSO connected) 10
				MΩ (× 10, with VT DSO connected) |
				| Input Capacitance |
				14 pF ~ 18 pF (× 10), 70 pF ~ 120
				pF (× 1) |
				| Input Capacitance Compensation Range |
				15 ~ 45 pF |
				| Length |
				1.2 m |
		Accessories include: a 12 cm snap-on rotating ground lead, a sprung
		hook, two marker rings, a probe compensation adjustment tool, two probe
		tip caps.
		 1)
		Measurements of PAL Composite Video Signals
		2) Measurements of a 500Hz sine wave and a 1kHz square wave under ALT
		trigger mode
		3) Mixed signal display. Channels A & B are analog input channels while
		Channel EXT is used as a digital input channel
		 4) Transfer Function Measurement using Frequency Stepped Sine Signal from 1Hz to
		25MHz and Auto Ranging Algorithm
		(Device Test Plan required)
		 5) Impedance & Phase Measurement using Frequency Stepped Sine Signal from 1Hz to
		25MHz and Auto Ranging Algorithm (Device Test Plan required)
		6) Impedance & Phase vs Frequency of a filter using swept sine from
		50kHz to 100kHz (Multi-Instrument Pro required)
