Model CA-YD |
				Sensitivity
				(pC/g) |
				Frequency Response
				±5% (Hz) |
				Operating Range
				(g) |
				Shock Limit (g) |
				Weight (gram) |
				Size (mm) |
				Mounting |
				Datasheet |
				Unit Price
				Free Express Shipping |
				General-Purpose |
				  103 |
				20 |
				0.5~12k |
				2000 |
				>2000 |
				14 |
				Φ11×19 |
				M5  |
				US$109.95
				106 |
				25 |
				0.5~12k |
				2000  |
				>2000 |
				15  |
				Φ15×21.5 |
				M5  |
				US$119.95
				107 |
				50 |
				0.5~6k |
				1000 |
				>1000 |
				28  |
				Φ18.5×27 |
				M5 |
				US$149.95
				108 |
				100 |
				0.5~6k |
				1000 |
				>1000 |
				28  |
				Φ18.5×27 |
				M5 |
				US$169.95
				  127 |
				150 |
				0.3~5k |
				600 |
				>600 |
				38 |
				Φ20×28 |
				M5 |
				US$219.95
				  128 |
				30 |
				0.5~10k |
				2000 |
				>2000 |
				18 |
				Φ15×25 |
				M5 |
				US$159.95
				129 |
				10 |
				1~7k |
				2000 |
				>2000 |
				9  |
				Φ15×9.5 |
				M4 Through hole or M5 stud |
				US$169.95
				  130 |
				3 |
				2~5k |
				2000  |
				>2000 |
				2.8  |
				Φ11×9.2 |
				Adhesive  |
				US$269.95
				  140 |
				2 |
				5~10k |
				2000 |
				5000 |
				1.4 |
				Φ7.5×4.6 |
				Φ2 through hole  or Adhesive  |
				US$589.95
				Low-Frequency High
				Sensitivity
				  109 |
				2500 |
				0.1~1k |
				40  |
				>40 |
				210 |
				Φ38×29 |
				M5 |
				US$299.95
				117 |
				500 |
				0.3~3k |
				150  |
				>150 |
				59 |
				Φ23×20 |
				M5 |
				US$279.95
				  119
				(109A) |
				10000 |
				0.2~500 |
				10  |
				>10 |
				300 |
				Φ36.5×38 |
				M8 |
				US$399.95
				High Shock
				102 |
				15 |
				2~10k |
				5000  |
				>5000 |
				14 |
				Φ14×22.5 |
				M5 |
				US$144.95
				111 |
				0.03 |
				5~15k |
				50000  |
				>50000 |
				6  |
				Φ12.6×21.3 |
				M5 |
				US$539.95
				111A |
				0.5  |
				5~20k |
				30000  |
				>30000 |
				10  |
				Φ12.6×21.3 |
				M5 |
				US$509.95
				115 |
				7  |
				5~15k |
				7000  |
				>7000 |
				9  |
				Φ13×13 |
				M3 |
				US$164.95
				125 |
				1  |
				5~15k |
				10000  |
				>10000 |
				1.5  |
				Φ10.5×4.6 |
				Adhesive  |
				US$509.95
				126 |
				2 |
				5~15k |
				20000  |
				>20000 |
				4  |
				Φ8.5×10 |
				Adhesive  |
				US$209.95
				139 |
				10  |
				1~10k |
				2000  |
				>2000 |
				5  |
				Φ11.5×15 |
				M3 |
				US$209.95
				High
				Temperature
				  112
				(Differential) |
				50 |
				5~3k |
				100  |
				>100 |
				105 |
				Φ40×37 |
				3×M4 or M5 |
				US$1099.95
				112A (Differential) |
				50 |
				2~3k |
				100  |
				>100 |
				95 |
				Φ36.1×30.5 |
				3×M4 or M5 |
				US$589.95
				136 |
				3  |
				5~8k |
				500  |
				3000 |
				29  |
				Φ18×23 |
				M5 |
				US$329.95
				Standard or Normalized
				113 (Normalized) |
				10 |
				1~8k |
				5000 |
				>5000 |
				11 |
				Φ14.5×17 |
				M5 |
				US$264.95
				122 (Standard) |
				1.2  |
				5~5k |
				1000 |
				>1000 |
				38 |
				Φ16.5×25.5 |
				M5 |
				US$679.95
				Industrial Monitoring
				104T |
				35 |
				1~7k |
				800 |
				>800 |
				33 |
				Φ16.5×35 |
				M5 |
				US$149.95
				| 2. Charge-mode
				Piezoelectric Force Sensor CL-YD series  |
				Model CL-YD |
				Sensitivity ± 5%
				(pC/N) |
				Operating Range
				(N) |
				Weight (gram) |
				Size (mm) |
				Mounting |
				Datasheet |
				Unit Price
				Unidirectional
				301 |
				4 |
				0~5000 |
				11 |
				Φ16×8 |
				Adhesive  or fixture  |
				US$224.95
				303 |
				4 |
				0~2000 |
				16 |
				Φ16×20 |
				M5  |
				US$299.95
				305 |
				4 |
				0~60000 |
				34 |
				Φ26×13 |
				Φ8.2 through hole |
				US$494.95
				312 |
				4 |
				0~5000 |
				14 |
				Φ18×8.5 |
				Φ6 through hole |
				US$339.95
				320 |
				4 |
				0~200000 |
				150 |
				Φ50×16.5 |
				Φ20 through hole |
				US$749.95
				360 |
				2  |
				0~600000 |
				805 |
				Φ95×21.5 |
				Φ40 through hole |
				US$1599.95
				Bidirectional
				2311 |
				3 |
				±10000 |
				145 |
				Φ31×48 |
				M12  |
				US$574.95
				2312 |
				3 |
				±5000 |
				50 |
				Φ17.8×30 |
				M5  |
				US$399.95
					| 3. Charge-mode Piezoelectric Impedance
					Heads |
					CL-YD-331 |
					Force Sensor
					Sensitivity: 4 pC/N; Range: ±1000 N;
  Accelerometer: Sensitivity: 50
					pC/g;
					Range: 400 g;  Frequency Response (±0.5 dB): 1 Hz ~ 4 kHz  |
					Weight: 58g Mounting: M5
					US$509.95
					| 4. Charge-mode Piezoelectric Impact
					Harmmers |
					LC-01A |
					Measurement
					Range: 2 kN; Sensitivity:  4 pC/N |
					US$439.95
					LC-02A |
					Measurement
					Range: 5 kN; Sensitivity:  4 pC/N |
					US$539.95
					LC-04A |
					Measurement
					Range: 60 kN; Sensitivity:  4 pC/N |
					US$659.95
				| 5. Charge-mode
				Piezoelectric Pressure Sensor CY-YD series  |
				Model CY-YD |
				Sensitivity ± 5%
				(pC/MPa) |
				Operating Range
				(Pa) |
				Weight (gram) |
				Size (mm) |
				Mounting |
				Datasheet |
				Unit Price
				200 |
				200  |
				0~15M |
				28 |
				Φ16×37 |
				M14  |
				US$479.95
				202 |
				350 |
				0~10M |
				45  |
				Φ11×108 |
				M5  |
				US$719.95
				203 |
				100 |
				0~30M or 0~60M  selectable |
				6  |
				Φ10×21 |
				Adaptive  clamper  |
				US$224.95
				205 |
				100 |
				11  |
				Φ14×25 |
				M10  |
				US$224.95
				211 |
				50000 |
				50~1M |
				25  |
				Φ16×27.5 |
				M14  |
				US$269.95
				212 |
				100 |
				0~10M |
				6 |
				Φ10×21 |
				Adaptive clamper  |
				US$399.95
				214 |
				30 |
				0~200M |
				20  |
				Φ10×33 |
				M10  |
				US$384.95
				| 6. Charge-mode
				Piezoelectric Hydrophones  |
				| Model |
				Sensitivity
				(re 1V/µPa) |
				Frequency Range |
				Sensor Weight (g) |
				Sensor Size(mm) |
				Operating Depth (m) |
				Datasheet |
				Unit Price
				HDP-H1A |
				-185 dB (560 µV/Pa) 11.2
				pC/Pa (Nominal) |
				20Hz~4kHz (±4dB) |
				105 |
				Φ25×46 |
				80 |
				US$349.95
				HDP-H3B |
				-192dB
				(250 µV/Pa) 3.8 pC/Pa (Nominal) |
				20Hz~10kHz (±5dB) |
				10+150
				Φ17×32 |
				80 |
				US$449.95
				HDP-AS1 |
				-208 (±3dB)
				(40 µV/Pa) 0.26 pC/Pa
				1Hz~100kHz (±2dB) |
				8+150  |
				Φ12×40 |
				200  |
				US$649.95
					| 7. Calibration
					Capacitors |
					VT-CAP |
					VT CAP is a precision capacitor epoxy-sealed inside a metal case with BNC connectors at both ends. It can be used in series with a voltage signal generator in order to simulate charge output during
					calibration or checking of a charge amplifier. The capacitor has a low dissipation factor, low dielectric absorption coefficient and very constant capacitance against temperature and humidity variation.
					 Available nominal capacitance options are: 10 pF, 100
					pF, 1 nF, 10 nF, 100 nF  |
					US$69.95
					| 8. Magnetic
					Mounting Bases |
					Mouting thread: 1/4-28 UNF, Size: Φ30×12 mm, Weight:
					52g, Magnetic Force: 200N, Max. Acceleration: 300g |
					US$49.95
					Mounting thread: M5, Size: Φ30×12 mm, Weight:
					US$49.95
					| 9. Vibration
					Calibrators |
					VIB-CAL-606 |
					The Handheld vibration calibrator
					VIB-CAL-606 is a small, self-contained handheld shaker
					designed for quick and easy checking of accelerometers and
					vibration measurement systems, providing a known and
					controlled RMS vibration for verification of accelerometers
					weighing up to 150g (including cable).
					US$599.95
