PC USB 24-bit dual-channel 48 kSPS 0.03Hz~23kHz Data Acquisition Interface with Charge Input /
				Digital Charge Amplifier
				Manual
				                      US$599.95
				Free Express Shipping
						| VT CAMP-2G05 |
						VT CAMP-2G05A |
						VT CAMP-2G05B |
				VT CAMP-2G05 is a 24-bit, dual-channel, USB data acquisition interface specially designed for use with sensors with electric charge output such as piezoelectric sensors. Each channel has a built-in charge amplifier with 12 calibrated charge measurement ranges for easy calibration to sensor sensitivity: ± 250 pC, ± 500 pC, ± 1 nC, ± 2.5 nC, ± 5 nC, ± 10 nC, ± 25 nC, ± 50 nC, ± 100 nC, ± 250 nC, ± 500 nC, ± 1 µC.  High-precision capacitors with low dissipation factors, low dielectric absorptions and very constant capacitance values against temperature and humidity variation are used in the charge amplifiers to convert charge to voltage.
				The charge amplifiers are equipped with an overload indicator and a reset facility. Each channel contains a hardware high-pass filter with 5 selectable -3dB corner frequencies: None (0.03 Hz), 1.8 Hz, 119 Hz, 236 Hz and 464 Hz.  The signals sensed by the charge-output sensors can be amplified and output directly from
				the stereo headphone jack even without running the PC software.  When used in conjunction with the Multi-Instrument® software, the setup allows you to take reliable and quality vibration and noise measurements as simply as plug & play. No external power supply and driver installation is required. It is a truly hassle-free portable vibration and noise test & measurement solution.   VT CAMP-2G05A has the same specifications as VT CAMP-2G05, except that its Channel B has a 60 dB higher analog gain, with its charge measurement ranges changed to: ± 250 fC, ±500 fC, ± 1 pC, ± 2.5 pC, ± 5 pC, ± 10 pC, ± 25 pC, ± 50 pC, ± 100 pC, ± 250 pC, ± 500 pC, ± 1 nC. The increased gain makes it more capable of measuring low level signals such as a low-dB sound in water.
				 VT CAMP-2G05B has the same specifications as VT CAMP-2G05, except that its two input channels A & B have a 60 dB higher analog gain, with their charge measurement ranges changed to: ± 250 fC, ± 500 fC, ± 1 pC, ± 2.5 pC, ± 5 pC, ± 10 pC, ± 25 pC, ± 50 pC, ± 100 pC, ± 250 pC, ± 500 pC, ± 1 nC. The increased gain makes it more capable of measuring low level signals such as a low-dB sound in water.
				 It is possible to run multiple VT CAMP-2G05/A/B using multiple instances of the software on the same computer.
		1) VT CAMP-2G05/A/B unit with a hardware
		activated Multi-Instrument Standard
		software license 2) USB cable (1.5 m)  3) CD (contains the
		copy-protected Multi-Instrument Software)  4) Carrying case
  3. Optional Items
		You may follow the links below to purchase the optional items: 1)
		Charge-mode Piezoelectric
		Accelerometers,
		Force Sensors,
		 Impedance Heads,
		Impact Hammers,
		Pressure Sensors, (including
		a mounting stud / screw and a cable from sensor to BNC, default: 2m)
		2) Charge-mode Piezoelectric Contact Microphones  3) Charge-mode
		Piezoelectric Film Sensors 4)
		Hydrophones 5)
		Magnetic Mounting Bases
		6) Software License
		Upgrades 7) USB Isolators 8)
		Calibration Capacitors   Note: It is usually possible to place the
		optional items inside the same carrying case with VT CAMP-2G05/A/B.
		4.
		Hardware Specifications
				| Number of Input Channels |
				2 |
				| Sampling Frequency |
				48 kHz (original), 44.1
				kHz, 32 kHz, 22.05 kHz, 16 kHz, 11.025 kHz, 8 kHz, 4 kHz, 2 kHz
				| ADC Bit Resolution |
				24 Bits (can be reduced to
				16 bits or 8 bits) |
				| Input Charge Ranges |
				CAMP-2G05: ± 250 pC, ± 500 pC, ± 1 nC, ± 2.5 nC, ± 5 nC, ± 10 nC, ± 25
				CAMP-2G05A: Ch.A: ± 250 pC, ± 500 pC, ± 1 nC, ± 2.5 nC, ± 5
				nC, ±10 nC, ± 25 nC, ± 50 nC, ± 100 nC, ± 250 nC, ± 500 nC,
				± 1 µC Ch.B: ± 250 fC, ± 500 fC, ± 1 pC, ± 2.5 pC, ± 5 pC,
				±10 pC, ± 25 pC, ± 50 pC, ± 100 pC, ± 250 pC, ± 500 pC,  ± 1
				nC
  CAMP-2G05B: ± 250 fC, ± 500 fC, ± 1 pC, ± 2.5 pC, ±
				1 nC
				| Input Connectors &
				Interface |
				BNC, Single Ended |
				| Input Coupling Type |
				AC (High-pass filtered at
				0.03 Hz) |
				| Input Isolation |
				No (Isolation can be
				achieved through a USB isolator) |
				| (Voltage) Input Impedance |
				1 kΩ |
				| Input High Pass Filter |
				None, 1.8 Hz, 119 Hz, 236
				Hz, 464 Hz |
				| Charge Amplifier Time Constants |
				CAMP-2G05: 1210 s(6
				Higher Ranges), 12.1 s (6 Lower Ranges)
  CAMP-2G05A:
				Ch.A: 1210 s (6 Higher Ranges), 12.1 s (6 Lower Ranges) Ch.B:
				1.21 s (6 Higher Ranges), 0.0121 s (6 Lower Ranges)
				CAMP-2G05B: 1.21 s (6 Higher Ranges), 0.0121 s (6 Lower
				Ranges) |
				| Frequency Response |
				CAMP-2G05: 0.03 Hz ~ 22.8 kHz
				 CAMP-2G05A: Ch.A: 0.03 Hz ~ 22.8 kHz Ch.B: 0.13Hz ~
				22.8 kHz (6 Higher Ranges); 13 Hz ~ 22.8 kHz (6 Lower Ranges)
				 CAMP-2G05B: 0.13Hz ~ 22.8 kHz (6 Higher Ranges); 13 Hz ~
				22.8 kHz (6 Lower Ranges) |
				| Frequency Accuracy |
				50 PPM |
				| Anti-aliasing Filter |
				22.8 kHz at Sampling Rate
				48 kHz, proportionally adaptive to Sampling Rate Chosen |
				| Buffer Size |
				Virtually unlimited
				(streaming mode) |
				| Charge Accuracy |
				±0.5% at 1000Hz
				(FS>=250pC); ±2% at 1000Hz	(FS<250pC);  |
				| Output Connector &
				Interface |
				ϕ3.5 mm Stereo Audio Jack |
				| Output Voltage Range |
				 ±0.5 V |
				| Digital Input / Output
				Standard |
				USB Audio Class 1 |
				Calibration |
				Individually done at factory, user re-calibratable |
				| PC Interface |
				USB 2.0 Full Speed / USB
				1.1 |
				| Device Category
				in Multi-Instrument |
				ADC Device |
				Sound Card MME |
				| DAC Device |
				Not Applicable |
				| Power |
				Bus powered by USB port, no
				external power source required |
				| Power Consumption |
				Max. 0.5W |
				| Dimensions |
				128 mm (L) × 57 mm (W) × 24
				mm (H),   anodized aluminum case |
				| Operating Temperature |
				0° C ~50° C |
				| System Requirements |
				Windows XP, Vista, 7, 8,
				8.1, 10, 11 or above, 32 bit or 64 bit |
		 Frequency Response of Built-in High Pass Filter (sampled at 48 kHz)
  (1) VT
		CAMP-2G05 with Multi-Instrument Pro + Spectrum 3D Plot
		 (2) VT CAMP-2G05 with Multi-Instrument Pro + Spectrum 3D Plot + Vibrometer
		 (3) Half-sine Shock Test (Video:
		ShockTestWithMulti-Instrument.mp4 )
		 (4) Five Types of Shock Response Spectrum of a Half-sine pulse (Note: Multi-Instrument Pro or above is required)
		Absolute Acceleration Shock Response Spectrum (Multi-Instrument Pro or
		above is required)
		Relative Velocity Shock Response Spectrum (Multi-Instrument Full Package
		is required)
		Relative Displacement Shock Response Spectrum (Multi-Instrument Full
		Package is required)
		Pseudo Velocity Shock Response Spectrum (Multi-Instrument Full Package
		is required)
		Equivalent Static Acceleration Shock Response Spectrum (Multi-Instrument
		Full Package is required)
		 (5) Damping Ratio and Q factor Measurement using Free Vibration Decay method and Half-Power method (Note: Multi-Instrument Full Package is required)
