PC USB 24-bit dual-channel 48 kSPS 0.03Hz~23kHz
				IEPE Data Acquisition Interface
				Manual                       US$399.95
				Free Express Shipping
						| VT IEPE-2G05 |
						VT IEPE-2G05A |
						VT IEPE-2G05B |
						| VT IEPE-2G05C |
						VT IEPE-2G05D |
						VT IEPE-2G05E |
				 VT IEPE-2G05 is a 24-bit, dual-channel, USB data acquisition
				interface specially designed for use with IEPE sensors such as
				IEPE accelerometers, IEPE microphones and IEPE hydrophones. Each
				channel has six calibrated voltage measurement ranges for easy
				calibration to sensor sensitivity: ± 250 mV, ± 500 mV, ± 1 V, ±
				2.5 V, ± 5 V, ± 10 V, and a built-in 24V 4mA current source to
				drive an IEPE sensor directly. It contains a hardware high pass
				filter with 5 selectable -3dB corner frequencies: None (0.03Hz),
				1.8 Hz, 119 Hz, 236 Hz, 464 Hz. The signals sensed by the IEPE
				sensors can be amplified and output directly from the stereo
				headphone jack even without running the PC software.  When
				used in conjunction with the Multi-Instrument®
				software, the setup allows you to take reliable and quality
				vibration measurements as simply as plug & play. No external
				power supply and driver installation is required. It is a truly
				hassle-free portable
				noise and vibration measurement solution.
  VT IEPE-2G05A has the same specifications as VT IEPE-2G05, except that its Channel B has a 20 dB higher analog gain, with its voltage measurement ranges changed to: ± 25 mV, ± 50 mV, ± 100 mV, ± 250 mV, ± 500 mV, ± 1 V. The increased gain makes it more capable of measuring low level signals such as a low-dBSPL sound.
		  VT IEPE-2G05B has the same specifications as VT IEPE-2G05, except that its two input channels A & B have a 20 dB higher analog gain, with their voltage measurement ranges changed to: ± 25 mV, ± 50 mV, ± 100 mV, ± 250 mV, ± 500 mV, ± 1 V. The increased gain makes it more capable of measuring low level signals such as a low-dBSPL sound.
  VT IEPE-2G05C/D/E have the same specifications as VT IEPE-2G05, except that their Channels B have a 40 dB higher analog gain, with their voltage measurement ranges changed to: ± 2.5 mV, ± 5 mV, ± 10 mV, ± 25 mV, ± 50 mV, ± 100 mV. The increased gain makes them more capable of measuring extra low-dBSPL sound. Their Channels A have a 0dB /20dB / 40dB higher analog gain respectively than that of VT IEPE-2G05.
  All the above models can be switched to a voltage measurement mode (e.g. for the purpose of accepting the voltage pulses output by a
		non-IEPE tachometer) by cutting off the 24V 4mA constant current supply through an internal DIP switch in each channel. The 4mA constant driving current can be modified as well (e.g. for the purpose of driving a very long cable). These customizations are recommended to be done in the factory upon request before shipping.
  It is possible to run multiple VT IEPE-2G05/A/B/C/D/E using multiple instances of the software on the same computer.
		1) VT IEPE-2G05/A/B/C/D/E unit with a hardware
		activated Multi-Instrument Standard
		software license 2) USB cable (1.5 m)  3) CD (contains the
		copy-protected Multi-Instrument Software)  4) Carrying case
  3. Optional Items
		You may follow the links below to purchase the optional items: 1)
		IEPE Accelerometers,
		IEPE Velocity Sensors,
		IEPE Impedance Heads,
		IEPE Impact Hammers (including
		a mounting stud / screw and a cable from sensor to BNC, default: 2m) 2)
		IEPE Measurement Microphones
		(including a small mic stand, a mic clip and a cable from mic to BNC,
		default: 2m)  3) IEPE
		Measurement Hydrophones 4)
		Magnetic Mounting Bases
		5) Software License
		Upgrades 6) USB Isolators 7) IEPE simulators   Note: It is usually possible to place the
		optional items inside the same carrying case with VT IEPE-2G05/A/B/C/D/E.
		4.
		Hardware Specifications
				| Number of Input Channels |
				2 |
				| Sampling Frequency |
				48 kHz (original), 44.1
				kHz, 32 kHz, 22.05 kHz, 16 kHz, 11.025 kHz, 8 kHz, 4 kHz, 2 kHz
				| ADC Bit Resolution |
				24 Bits (can be reduced to
				16 bits or 8 bits) |
				| Input Voltage Ranges |
				IEPE-2G05: ± 250 mV, ± 500 mV, ± 1 V,
				± 2.5 V, ± 5 V, ± 10 V
  IEPE-2G05A: Ch.A: ± 250 mV, ±
				500 mV, ± 1 V, ± 2.5 V, ± 5 V, ± 10 V Ch.B: ± 25 mV, ± 50 mV,
  IEPE-2G05B: ± 25
				IEPE-2G05C: Ch.A: ± 250 mV, ± 500 mV, ± 1 V, ± 2.5 V, ± 5 V, ± 10 V
				Ch.B: ±2.5 mV, ±5 mV, ±10 mV, ±25 mV, ±50 mV, ± 100 mV
				IEPE-2G05D: Ch.A: ± 25 mV, ± 50 mV, ± 100 mV, ± 250 mV, ± 500 mV,
				± 1V Ch.B: ± 2.5 mV, ± 5 mV, ± 10 mV, ± 25 mV, ± 50 mV, ± 100 mV
				 IEPE-2G05E: ± 2.5 mV, ± 5 mV, ± 10 mV, ± 25 mV, ± 50 mV, ± 100
				mV |
				| Input Connectors &
				Interface |
				BNC, Single Ended, IEPE,
				24V 4mA |
				| Input Coupling Type |
				IEPE-2G05: AC (High pass filtered at
				0.03Hz)
  IEPE-2G05A:  Ch.A: AC (High pass filtered at
				0.03Hz) Ch.B: AC (High pass filtered at 0.3Hz)
				IEPE-2G05B: AC (High pass filtered at 0.3Hz)
  IEPE-2G05C:
				 Ch.A: AC (High pass filtered at 0.03 Hz) Ch.B: AC (High pass filtered at 3 Hz)
				 IEPE-2G05D: Ch.A: AC (High pass filtered at 0.3 Hz) Ch.B: AC (High pass filtered at 3 Hz)
  IEPE-2G05E: AC (High pass filtered at 3 Hz) |
				| Input Isolation |
				No (Isolation can be
				achieved through a USB isolator) |
				| Input Impedance |
				IEPE-2G05: 510 kΩ
				IEPE-2G05A:  Ch.A: 510 kΩ Ch.B: 51 kΩ
  IEPE-2G05B:
				51 kΩ
  IEPE-2G05C:  Ch.A: 510 kΩ Ch.B: 5.1 kΩ
				 IEPE-2G05D:  Ch.A: 51 kΩ Ch.B: 5.1 kΩ
				IEPE-2G05E: 5.1 kΩ |
				| Input High Pass Filter |
				None, 1.8 Hz, 119 Hz, 236
				Hz, 464 Hz |
				| Frequency Response |
				IEPE-2G05: 0.03 Hz ~ 22.8 kHz
				 IEPE-2G05A: Ch.A: 0.03 Hz ~ 22.8 kHz Ch. B: 0.3 Hz ~
				22.8 kHz
  IEPE-2G05B: 0.3 Hz ~ 22.8 kHz
  IEPE-2G05C:
				 Ch.A:  0.03 Hz~22.8kHz Ch.B:  3 Hz~22.8kHz
  IEPE-2G05D: Ch.A:  0.3 Hz~22.8kHz Ch.B:  3 Hz~22.8kHz
  IEPE-2G05E:  3 Hz~22.8kHz |
				| Frequency Accuracy |
				50 PPM |
				| Anti-aliasing Filter |
				22.8 kHz at Sampling Rate
				48 kHz, proportionally adaptive to Sampling Rate Chosen |
				| Buffer Size |
				Virtually unlimited
				(streaming mode) |
				| Voltage Accuracy |
				±0.5% at 1 kHz |
				| Output Connector &
				Interface |
				ϕ3.5 mm Stereo Audio Jack |
				| Output Voltage Range |
				 ±0.5 V |
				| Digital Input / Output
				Standard |
				USB Audio Class 1 |
				Calibration |
				Individually done at factory, user re-calibratable |
				| PC Interface |
				USB 2.0 Full Speed / USB
				1.1 |
				| Device Category
				in Multi-Instrument |
				ADC Device |
				Sound Card MME |
				| DAC Device |
				Not Applicable |
				| Power |
				Bus powered by USB port, no
				external power source required |
				| Power Consumption |
				Max. 0.5W |
				| Dimensions |
				128 mm (L) × 57 mm (W) × 24
				mm (H),   anodized aluminum case |
				| Operating Temperature |
				0° C ~50° C |
				| System Requirements |
				Windows XP, Vista, 7, 8, 8.1, 10 or above, 32 bit or 64 bit |
		 Frequency Response of Built-in High Pass Filter (sampled at 48 kHz)
  (1) VT IEPE-2G05 with Multi-Instrument Pro + Spectrum 3D Plot
		 (2) VT IEPE-2G05 with Multi-Instrument Pro + Spectrum 3D Plot + Vibrometer
		 (3) Half-sine Shock Test (Video:
		ShockTestWithMulti-Instrument.mp4 )
		 (4)  Sound Quality Measurement
		dBSPL, Loudness,
		Loudness Level, Sharpness, Articulation Index and Open Articulation
		Index of a white noise in a Free Field with an IEPE	Measurement Microphone        (Note: Multi-Instrument Pro or above is required)
		 (5) Five Types of Shock Response Spectrum of a Half-sine Pulse
		Absolute Acceleration Shock Response Spectrum (Multi-Instrument Pro or
		above is
		required)
		Relative Velocity Shock Response Spectrum (Multi-Instrument
		Full Package is
		required)
		Relative Displacement Shock Response Spectrum (Multi-Instrument Full
		Package is required)
		   Pseudo
		Velocity Shock Response Spectrum (Multi-Instrument Full Package is
		required)
		Equivalent Static Acceleration Shock Response Spectrum (Multi-Instrument
		Full Package is
		required)
		 (6) Damping Ratio and Q factor Measurement using Free Vibration
		Decay method and Half-Power method
		(Note: Multi-Instrument Full Package is required)
	 (7) Simultaneous Sound Intensity and Sound Pressure Measurement using a
		P-P Sound Intensity Probe
