| VT RTA-268A/B/C | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
 ![]() Download and try the fully functional Multi-Instrument software using your sound card as the ADC and DAC device! 1. Introduction VT RTA-268A/B/C is a series of PC-based ultra-low-noise huge-dynamic-range real-time acoustic analyzers, powered by the comprehensive virtual instrument software, Multi-Instrument®. The USB audio interface used in the analyzers has two ADCs working in tandem to create a single output data stream in 32-bit float format. One “low gain” ADC is optimized for high-level signals, and the other “high gain” ADC is optimized for low-level signals. This state-of-the-art dual-ADC architecture provides unmatchable dynamic range compared with the conventional single ADC approach. With a proper microphone, it is now possible to capture sound across the entire human hearing range without sacrificing fidelity at low signal levels or encountering clipping at high signal levels, and this can be achieved without the hassle of manual analog gain adjustment and measurement range switching at all. VT RTA-268A/B/C has built-in DACs, so it can also be used as a stereo signal generator at the same time. 2. Package Contents 1) XLR Measurement microphone and its accessories (a windshield, a microphone clip and a small microphone stand) 2) XLR-to-USB Audio Interface 3) USB cable (1 m) 4) XLR cable (1.5 m) 5) CD (contains the copy-protected Multi-Instrument Software) 6) USB hardkey (contains a Multi-Instrument Pro License) 7) Audio Test WAV files (contains a list of audio test tones and noises) (download at AudioTestCD.zip or AudioTestCD.rar) 8) Carrying Case 9) Unique Sound Level Calibration Data (in CD) 10) Unique Microphone Calibration Data (in CD, only applicable to RTA-268C) Unique Calibration Files Download: RTA-268A Mic Serial Number M215-XXXXXX RTA-268B Mic Serial Number M215L-XXXXXX RTA-268C Mic Serial Number M50-XXXXXXX Other Customized Configuration: V210-XXXX-XXXX-XXXX 3. Optional Items 1) An additional XLR measurement microphone and its accessories 2) P48-to-IEPE converter (so that IEPE sensors can be connected to the XLR input) 3) IEPE sensors 4) Software license upgrade 4. VT RTA-268A/B/C Hardware Configuration
 5. Overall VT RTA-268A/B/C Specifications
 6. UAC-232 Audio Interface Specifications
 ![]() Typical Magnitude Frequency Response of XLR Input @ Sampling Rate 192kHz ![]() THD, THD+N, SNR, SNAD, ENOB of XLR Input @ 1kHz, 1Vp ![]() SMPTE IMD of XLR Input @ 1Vp 7. Measurement Microphone M215 Specifications (for VT RTA-268A)
 ![]() Typical Polar Pattern of M215 ![]() Typical Frequency Response of M215 8. Measurement Microphone M215L Specifications (for VT RTA-268B)
 9. Measurement Microphone M50 Specifications (for VT RTA-268C)
 ![]() Typical Polar Pattern of M50 ![]() Typical Frequency Response of M50 Note: This is only a typical frequency response chart. The measurement microphone M50 is calibrated individually and the calibration data is included in the product package. 10. Some Applications 1. Polarity Check for Speakers, Microphones and Amplifiers using Multi-Instrument 2. Magnitude Frequency Response Measurement using Octave Analysis with Periodic Pink Noise Excitation (no averaging is required unlike the case of pink noise) ![]() 3. Measurement of Reverberation and Its Related Acoustic Parameters using the Interrupted Noise Method (Note: Multi-Instrument Pro or above is required) ![]() 4. Measurement of Reverberation and Speech Intelligibility Parameters using the Integrated Impulse Response Method (Note: Multi-Instrument Pro or above is required) ![]() ![]() 5. Discontinuity Measurement for Detection of Glitch, Digital Dropout, Speaker Rub and Buzz (Note: Multi-Instrument Pro or above is required) ![]() 6. Sound Quality Measurement Example - Loudness, Loudness Level, Sharpness of a white noise in a Free Field (Note: Multi-Instrument Pro or above is required) ![]() 7. Live Music Broadcast Latency Measurement using Generalized Cross Correlation with Software-Switchable Mixer-Level Loopback As Time Reference ![]()  |
